[ QUOTE ]
AL B said:
But I am confused at the moment. Why do all the cars listed above, S3, TT, A3 Quattro, R32, all have a much thicker front ant-roll bar? Usually by a factor of 4mm? /ubbthreads/images/graemlins/confused.gif
[/ QUOTE ]
I'll add another word to lost it's answer, just to help quantify things:
Distribution.
Weight distribution....loads more weight at the front of our cars than at the rear.
To be honest here:
You can spend your time (as much of it as you want!) sorting out thicker anti-roll bars to try and quash understeer...but there are subtle differences between understeer and lack of front end grip / bite.
Adding larger anti roll bars - especially at the rear - *should* assist in reducing understeer....but if you still have the crap Audi standard suspension settings you will not have increased the front end bite.
On a long sweeping bend, the car will probably feel flatter and more neutral with larger bars fitted...you may even be able to 'loosen' up the rear by going for a really big rear bar...but try going into a tight corner too hot and you simply wont have the bite to get the chassis working properly.
Something needs to be done to try and get the front end to turn in correctly - and that to me means turn in quickly, precisely with good feel and far more grip than standard....this should then allow the front outer tyre to take the load and allow the rest of the chassis to pivot around this loaded tyre....which will allow the rest of the chassis to 'work'.
In my eyes...this means adding two things that the wooly, super safe Audi suspension settings do not have:
Front negative camber.
Front toe out.
Anyone who is following where I'm going with this will be aware that having a front end that doesn't wash out at every opportunity is the only real starting point for subtle chassis tuning - which is what anti-roll bar tuning is in my opinion.
So, before everyone rushes out and orders ETKAs full collection of ARBs...try some aggressive settings on your front suspension first, and see how far up the grip ladder you can move your starting point, before attempting to fix a problem that may not be the problem at all!
I have done some front end mods (negative camber & toe out)...and I need more to get it to where I'll be satisfied...then, and only then, will I try to alter the chassis cornering attitude.
All that adding larger bars all round is going to do to a badly front end gripping car, is to allow it to understeer off the road whilst remaining nice and flat!
Not ideal at all.
Go with the front end adjustments...they are free!!
Then, and only then, try anti-roll bars.
Of course, you all may think I'm talking ********...which is fine. But these are my views and they work for me...and anyone who has driven my S3 or experienced it on one of the runs, will concur that it handles far better than it should, based upon the limited additional parts fitted!
Glen.
