Chris NottMonster Motorsport
    Sep 2007
    81
    s3 gauge cluster in an a3?
    has anyone ever done the swap or know if it will work?
    Sep 2007
    81
    yes no?
    grathies's Avatar
    More Points Than Portsmouth FC
    Dec 2004
    Portsmouth, Hampshire
    1,355
    Dont see why it wouldnt, just seems a waste of time tho
    You do get issues with them not working tho, and you find that on the S3 there are about 5 different clusters but they all look the same, its to do with PR build codes for signal type and pick up etc
    Sep 2007
    81
    just asking because i need a new cluster for my a3 and i found some for s3's.
    im basically looking for any solution to this problem.
    grathies's Avatar
    Dec 2004
    1,355
    As I say, you have to be careful with coding issues, can have problems with the ecu and convienience control unit etc
    Id personally get it sortd with a new unit rather than piss about with 2nd hand units
    Plus then the new clocks would be coded to the correct milage keeping things nice and in line
