Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Soon be christmas!!!!!!!!!!
    Feb 2008
    North Wales
    163
    broken spring whilst on holiday :-( PLEASE HELP!!!
    well, whilst trying to enjoy a holiday in northern scotland one of my front springs decided to snap. great. Found local garage and he has replaced the o/s spring and top mount (180!!!!!!! ouch). I wanted to do both sides but cant afford it at the mo. I did tell him that it was a sport model and thus has slightly lower suspension. Picked the car up this morning and surprise surprise it isnt sitting right. The o/s seems to be about 10mm higher. I also noticed that the n/s top mount is sitting higher than the other (ie its protruding more from the turret). This doesnt seem right at all. The car feels ok although i cant test in on a dual carridgeway or motorway until i get home. I did hear the guy quote the reg when he ordered the parts (non gen). I think its the wrong spring. Will it settle at all? Have driven about 35 miles today with no change. Please can anyone shed some light on this?????
    Cheers for reading!
    Feb 2008
    North Wales
    163
    checked out the mounts this morning and the new one is gen and is correct. does anyone know if i can expect the car to settle or could the ride height be due to a worn top mount????
    s3ollie's Avatar
    Jan 2007
    749
    the top mount do squash down over time. someone on here changed their mount and gained about 10mm per side. so you could change the other one and bring it in line but they will both be higher than before! i believe the springs will settle a little but will prob be uneven if you dont change them both
    8P S3
    Feb 2008
    North Wales
    163
    cheers dude! hopefully, as you say it'll settle a bit. only time will tell. I'm prob gonna lower it when i put some bigger wheels on so i guess it's not the end of the world
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    when I changed top mounts I went UP 15mm per side! the old ones were VERY squished in comparison to the brand new ones.
    Give it a few weeks, and it'll settle a bit, but nowhere near as much as the other side I wouldnt think. You really need to do both.
    Dec 2006
    190
    yeah they should wear in, if you wanted them sitting the same you should of replaced both sides.
    Feb 2007
    UK
    229
    mine have squased a bit, both sides are similar, tho not the same, 2002 S3 with 55,000mls.
    Feb 2008
    North Wales
    163
    Cheers for the input troops! I would have done both sides if i was at home but i'm about 400 miles away! Seems better every time i drive it, think i was just being a bit parnoid!!!!! Thanks again for everyones help. Just gotta sell the mk2 at ultimate dubs then i can stuck into the audi, woohoo
