Volks AutosChris Nott
Results 1 to 7 of 7
Thread: Screen Wash
    Feb 2006
    glasgow
    45
    Screen Wash
    Hi
    My Screen wash is not working, I have checked my screen wash tank and is full.
    When i press the lever for the screen wash I can hear the motor but nothing is coming out.
    Does anyone have any suggests what the problem is????????
    Cheers in advance
    Nov 2007
    158
    Is it front or rear? there is prob a pip connected too the pump mite be worth checking if its on as may have fallen off.
    also i know in other cars ive had the jets can get blocked, worth checking with a needle but i guess if there no sign of any water then this prob isnt the cause.
    do you have the headlamp washers? worth puting on lights and giveing a good spray if they work the pump should be ok?
    Feb 2006
    glasgow
    45
    Checked it today water is leaking from underneath the car when I pull the lever for screenwash.
    Is it a pipe that has a hole in it. Will this be easy to fix, is it just the case wrapping tape round it if i find the leak.
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    If you can source the leak, replace the pipe/fitting, i cant see tape being a long term fix!
    Black S3
    spannah's Avatar
    Jul 2007
    N.London
    237
    i have the same problem, my rear dont work, and my water seems to empty out in a week or so without even using it.
    can somone tell us or put up a diy page
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    when my rear stopped working a pool of water appeared at the front left wheel while i was testing it, if you get this I have a couple of pics of the joint that can come apart behind the air box.
    red to red black to black blue to bits
    Nov 2007
    158
    Best thing too do just trace your pipes back and eventually u will find the leak, yeah wouldnt say tape is the best idae and probally insulating tape will just leak again anyway
