Monster MotorsportVolks Autos
Results 1 to 9 of 9
Thread: Split pipe Help
    Jay
    Aug 2006
    323
    Split pipe Help
    Hi guys,
    Ran vagcom which came up with 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    I think i've found the problem (see pics). The split is about an inch in length I've taped it up for the mean time and ran vag com again. The error hasn't come back but obviously car's running a bit funny.
    How big a job is it to get this fixed? and anyone know how or why this could have happened.
    cheers
    Jun 2003
    World of my own
    9,813
    That's definately not wear & tear, somebody has definately dropped something on it
    Alex Turner
    jesters3's Avatar
    The Shire's
    1,516
    Got the same issue on my S3 - 17705 and a split pipe. Found the split hideen between two pipes, looks to have just worn away; yours on the other hand does look 'forced' rather than worn. Even so, find the part number get a price and get it changed, looking at it you only have to undo a couple of clips; same as mine. So should only be a 5 min job once you have the part.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Jay
    Aug 2006
    323
    That did cross my mind... the only thing i've had done recently which would have involved removing the cover is a spark plug change even then i was stood next to the mechanic whilst he was changing them.
    What is this pipe? does it have anything to do with the turbo?
    Jester - was it the same pipe that had split on yours?
    Feb 2008
    22
    it looks like an oil carrier line?? best bet is to take it to audi, and get a part number and make sure you get new jubilees aswell.
    Apr 2007
    Wirral
    191
    I found the same split pipe on mine on the weekend,it had turned into a stretchy rubbery mush and had splits all over. its a crankcase breather hose, I got a replacement from the vw stealers cost 29!! part number is 06a103221bh.
    when replacing it i found the pipe that it joins onto was split too..bugger that cost me another 32..
    I also had the 17705 error and found the small vacuum pipe on the diverter valve was barely on, re-secured it, and boosts much stronger again.
    Jay
    Aug 2006
    323
    Quote Originally Posted by Emmo
    Didn't really need to hear that but at least i've got a good idea about costs involved.
    Was it pretty easy to fit?
    Apr 2007
    Wirral
    191
    It was dead easy to fit, you will need new jubilee clips, because the clips audi use are not reusable.
    only took 10 mins ish. Its held on by 3 clips pretty self explanatory.
    jesters3's Avatar
    The Shire's
    1,516
    Like Emmo says check other pipes as well. Looks to be a different engine to mine so different split. Mine is the Oil Carrier line 06A 103 221 AC
    Jester
