Volks AutosChris Nott
Thread: Vagcom
    Apr 2007
    30
    Vagcom
    Took the S3 for an mot this morning, Thankfully passed, The guy who did the mot had an Ibiza cupra 180bhp and he took the S3 out and thought it was a bit slow compared to his and said it may be either leaking boost or a Maf sensor gone! Now my question is do VAG charge you an hours labour to check it out and would i be better of getting them to check it when i get the cambelt done next week ! Is there any way of me checking if its leaking boost?
    Thanks in advance
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    vag will "usually" charge you a diagnostic fee to scan the car - IMO you'd be better off either buying a vagcom cable (if you have a laptop) and scanning it yourself or seeing if a nearby forum member has vagcom and can scan it for you.
    Not sure where your based but i'm in epsom (surrey) if thats any help and have vag.com?
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Longman's Avatar
    vassdignostics.co.uk
    Jul 2007
    Nr Maidstone, Kent
    I am in Kent, near the M20 too if that helps??
    Apr 2007
    30
    Thanks both for offers, Im in north wales so a bit far i think! Will try and sort something local
