AH FabricationsVolks Autos
    A3steve's Avatar
    Sep 2006
    126
    Rear caliper replacement
    Hi,
    I need to replace a rear caliper on a A3 which is siezed, But reading through the archives has revealed some horror stories.
    the replacement caliper is pre filled with fluid, and i have a hose clamp. physically changing it isnt a problem however
    When i replace the caliper do i need to bleed the whole system or can i get away with bleeding locally at the replaced caliper.
    secondly i will keep an eye on the fluid level in the master cylinder but where are the level indicators on the reservoir? i dont see any max/min?
    How much realistically do i need to bleed?
    thanks Steve
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I let the fluid run out by mistake as I swapped both rears at once and didn't realise how much had bled out, basically it's a bit of arse ache but not as bad as people make out, just bleed the cylinder then the brakes in the right order if you run low (or keep an eye on it as you said).
    A3steve's Avatar
    Sep 2006
    126
    Job done - Only needed to bleed at the caliper i replaced.
