Monster MotorsportChris Nott
Results 1 to 9 of 9
    807
    Question on service and cambelt
    Hi,
    When i take my a3 1.9tdi in for a service (nearly on 80k)
    should they advise me if cambelt needs changing? because i dont know when it was last done. Is it possible for them to tell if its on its way out?.
    just not sure.
    tx
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    The dealership may have a record of the cambelt being changed in the service history on their puters
    Likelikehood is that if it has been changed then it may well have been done by a independant.
    Suggest you find trusty local volks/audi mechanic and get a quote for to replace it particularly if you are planning on keeping for the car for a while.
    Prices will vary but have the water pump and tensioners and auxillary belt changed at the same time
    On a vehicle of that mileage I would recommend you have it done as soon as possible in case it has never been done - I think its unlikely that a visual inspection is going to reveal much.
    If you aint first you're last
    807
    tx for the reply,
    i will have to go through the service history properly and have a look. it was owned by car leasing (comany car thing) for a while who had it serviced up to about 60k i think. but will see what they say when i put it in for service ina cpl of months.
    tx
    ben
    rickquattro's Avatar
    May 2003
    Rickenback, German Black Forest
    588
    Spiker,
    Just reading round the info on here there are two examples of people having belts fail and facing four figure bills let alone the hassle of it failing by the side of the road. Can the leasing folk help at all, or maybe they were tied to a service contract at Audi?
    Worst case is they released the car just before the belts were due and it has been missed up to now... it would be quite a cost do do this at Audi.
    Go independent if you can find a good one, and as suggested do the water pump/tensioners etc at the same time.. circa 400 ish
    The second belt change is due around 120k miles which is way way too long for one belt in my opinion.
    HTH
    Coming back to Audi with an A3 Tdi Sportback Quattro... but the 220bhp T5 was epic....
    807
    ok when is the first change due? 60k?
    ta
    Jun 2003
    World of my own
    9,813
    60k or 4 years on TDi's
    Alex Turner
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    60k would be appropriate on a tdi
    Sep 2003
    medway,kent uk
    103
    cam belt
    following on i was told that my A6 1.9 tdi on a 54 plate does not need doing until 80 k although i will get it done at 4 years or 70k, whichever comes sooner.
    earlier years were 60k
    stevie
    Jan 2007
    Hampshire
    1,155
    I have heard of belt failures on car which have alledgedly had the belt 'changed' by the cars previous owner.
    Every car I have purchased has had the belt changed by me regardless of what the service history says. Doesnt cost much at all as I do most spannering jobs myself. Your facing a bill well into 4 figures if the belt were to snap and destroy the valves/cams/head. Not a risk worth taking in my humble opinion.
    A6 3.0 TDI.
