Chris NottBadger5
Results 1 to 14 of 14
Thread: oil consumption
    20
    oil consumption
    Hi,
    I viewed an A3 1.8T quattro (180 bhp on an 02 plate) over the weekend and the salesman mentioned i would have to check the oil level once a month as the audi engines "use oil", but this is nothing to worry about and normal. I am a little concerned as my golf had the same 1.8T engine (150 bhp) and over seven years never used a drop of oil.
    Any thoughts and experiences would be great, thanks.
    Ian.
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Mine does not burn any oil at at all.
    Black S3
    S3_Pricey's Avatar
    Nov 2006
    Worcester/Leamington Spa
    300
    neither does mine, check it every couple of weeks but never uses any
    S3, 2001 Facelift, 210bhp AMK,
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    Mine uses a little (1/4 quart) every 10K
    Nov 2007
    158
    So Far S3 isnt using any oil
    however a mate of mine driving a A3 1.9TDI his is using a fair bit of oil but i reckon theres something wrong not just as its a audi it uses oil!
    After all those 1.8T engines have been used in a few cars
    think the dealer may be trying too play u a bit!
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    As a backup to others, mine hardly uses any either. Never need a top up between services and I'm on the long life gubbins
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    i find the S3 uses oil if i use 0w 30/40 but hardly uses any 5w / 30,40. Sorry without going out in the cold can`t remember if its 30 or 40.
    New vw/audis are now speced at 5w and I suspect this is due to them useing oil
    red to red black to black blue to bits
    Dec 2006
    84
    i use a litre every 5,000 miles.
    normal oil consumption on an audi/vw engine can be 1 litre every 1,000 miles.
    the salesman is giving you good advice to check the oil regularly.
    S3_Pricey's Avatar
    Nov 2006
    300
    1 litre every 5000 miles? that does seem quite alot. i just know that on my a3 i never have to top up the oil
    Mar 2003
    153
    My first S3 didn't use a drop, current one does - though it has just swapped to using 5w as per Audi's new scheme so that may improve. Our 1.9Tdi A4 also uses a fair bit too. I trust my local dealer and they say it's quite normal.
    So I guess some do, some don't and from my own limited statistical analysis of three cars, I'd say more do than don't!
    20
    Thanks for your replies, i guess it's luck of the draw to how thirsty with oil your engine is.
    chris039's Avatar
    S3-A quality driving experience
    Worcester
    6
    My S3 uses a fair bit so does my VW diesel van, its due to the low friction engine and normal to use 1 litre every 1000 my be a bit less (depends how you drive it) mines tends to use more on short journeys. Can get expensive though if you use reccomended oil which only comes in 1 litre top ups!!
    Aug 2004
    526
    Another S3 that doesn't use oil and on 115K
    buckas's Avatar
    Sep 2006
    south west wales
    750
    Quote Originally Posted by Tastyterrier
    same
