Chris NottAH Fabrications
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Help - Electric seat not working!
    Hey guys, had a passenger in my car there and he raised the seatback to a more upright position, it went up ok but now wont go down, its not jammed forward as far as it will go. it moves up and down ok, and the lumbar support works fine.
    anyone any ideas and whether it's costly to fix - need it done asap as i cant get any passengers in it at the mo!!
    2001 Facelift S3, Custom Code Phase 1, Forge 007p
    Mo-S3's Avatar
    North West
    703
    Should be an easy and simple fix. There are 2 small micro switches fitted under the seat to the frame work. These can snap off or come off and get crushed between the frames. They are there to prevent the seat going too high or low and jamming the motor mechanism.
    Suggest you take the seat out and check these are intact.
    Shouldn't cost more then a pound to fix.
    Worse case is the switch is faulty in controls and then would be big money.
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    Thanks, will get that checked out tomorrow then.
