Chris NottAH Fabrications
Thread: Fuel Smell
    satanmademedoit's Avatar
    Nov 2007
    Ireland
    98
    Exclamation Fuel Smell
    HI all,
    Been having a problem with a strong smell of fuel when i open the drivers window of my S3. It tends to be only when the car is warm, usually get the smell when slowing down in traffic or stopped at lights.
    I have changed the fuel filter(as suggested on previous posts) and that seemed to make some difference, but the smell persists.
    The car has had a rear driver side quarter panel repair before i bought it. This smell seems to be coming from that side!
    I've checked the fuel supply and return lines but a cant see anything obvious! I know from past experience that a little fuel leak can smell like a huge gushing fountain so i may have missed something.
    Has anyone changed these lines before(see item 3 below)? Is it a major job? Does the tank need to be removed to access item 1,2 and 12?
    Any help is much needed!!!
    2001 S3 210
    Black
    Forge 007 DV
    Rebuilding Depleted Funds for Remap
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    It may be an idea to check that the fuel filter has been secured properly, the fitting has to be watertight or else a few drops may leak out which is enough to cause the fuel smell.
    Nov 2007
    Ireland
    98
    bump
    2001 S3 210
    Black
    Forge 007 DV
