Volks AutosAH Fabrications
Results 1 to 12 of 12
    Self Confessed Nightmare!
    Jun 2006
    Essex
    118
    Indicators not working
    i have a really odd fault with the A3.
    when i indicate, the green arrow comes on as it should, and the indicator, err, indicates as it should. this will only last a few seconds when the indicator arrow stops flashing and it doesn't flash at the side repeater or the headlight either.
    this happens both left and right - sometimes it doesn't work at all
    the hazzards work fine though.
    any thoughts? its driving me mad, i feel like a bit of a danger with no indicators!
    "If you always do what you've always done, you'll always get what you've always got"
    Dec 2006
    Sounds to me like the hazard switch m8, im sure it has a relay in it for the indicators. See if you can borrow one to try.
    James333's Avatar
    Dec 2007
    227
    the same thing happened on my sisters audi a3, identical symptons, got a hazard switch from ash_s3, swapped it and its fine now, i think one is about 30gbp from audi, and a 5 min job if you have radio extraction keys and know where the screws and clips are for the center console cover, hope this helps
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Aaaaaaaaaaaah yeah I remember now.
    Several people have had the same problem and yes, as above, Hazard switch.
    <Insert meaningless geeky specs here>
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Its the hazard relay, common problem.....
    Jun 2006
    Essex
    118
    lol @ dave!
    Thanks guys, i'll get that looked into
    Jun 2006
    Essex
    118
    Quote Originally Posted by James333
    before i start ripping the console apart, i cant find my haynes atm, but is there any guide to exactly where it is once the front is off? i have extraction keys so that part wont be an issue.
    thanks
    James333's Avatar
    Dec 2007
    227
    sorry, a guide to where what is???
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,911
    Indicator Relay Playing Up
    I had the same and found this but it seems to have fixed itself?!
    Jun 2006
    Essex
    118
    which screws amd clips which need to come out.
    i am a bit simple when it comes to fixing stuff and where as some people are happy to rip stuff apart, i like to know ecaxtly what im doing.
    i found haynes and they show cup holders, which i dont have, and not many other details
    voorhees - thanks, that link is for indicators that are ticking randomly, mine arent working at all.
    James333's Avatar
    Dec 2007
    227
    really sorry, cant remember where the clips are, its been a while since i did it, however, i just took my time and looked carefully, you can sort of feel where there is less flex so theres a clip beneath and thats where you want to pull, i went in blind and managed to do it without breaking anything so i can only suggest the same thing unless other ppl can reply with a more useful answer!! even though very vague, hope this helps a bit
    Jun 2006
    Essex
    118
    no worries, thanks James :o)
