Sky InsuranceVolks Autos
Thread: S3 seat problem
    7
    S3 seat problem
    Hi everyone,
    I am new here, I have an S3 the motor for the tilt function seems to have packed up in the drivers seat. Does anyone know anywhere i could get one, or where i would be able to just get two second hand front seat Recaros for the S3.
    I had a electrician take a look at the control panel for the seat, everything seems fine.
    Any help would be appreciated.
    Feb 2004
    2,036
    Ebay for full seats, but the motors are replaceable. Try the dealer!
    Otherwise a scrappy may have some all road a6s and some s4s have the same seats in the audi range. Ford fit them in the focus st.
    Failing all that, try recaro uk, they are up in Warwikshire somewhere, (honiton??) I am sure they can get you a new motor if not recommendd someone to repair it.
    Did your guy bypas the swithc to see if it worked? It may just be the switch.
    7
    He already checked for power to switch etc....so he has pretty much eliminated the switch. Thanks for the reply
    7
    Switch the problem!
    Hi Guys, looks like the Engineer was telling tales...the motor in the seat is fine, looks like i have a dodgy swtich. Ordered the part from audi, was given the wrong part for my car. I dont know what to do now, any help would be appreciated!!
    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    i have the same problem with mine, the tilt and the lumber dont work so i need to check my switch and motor. what did they charge you for the switch?
    NoggyDS3's Avatar
    Oct 2007
    Scotland
    193
    I've just had the switch replaced on the passenger seat. The price i paid seemed expensive to me but was told it was a pain to do and i ended up being over 200 (new switch and fitting/fixing) . My seat jammed forward as the switch jammed when it broke so that may have been an extra problem...I was worried that it might have been a motor but thankfully it was just the switch as i think motors are more expensive!!
    2001 Facelift S3, Custom Code Phase 1, Forge 007p
