Volks AutosAH Fabrications
Results 1 to 14 of 14
    Mar 2004
    238
    Is it my wastegate I can hear
    when I lift of the throttle I can hear a very quite woosh noise which I have heard on other cars and was told its the wastegate is this correct?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    Re: Is it my wastegate I can hear
    Its the DV when you let off the throttle pedal
    Mar 2004
    238
    thats what it sounds like but I haven't fitted a DV, do they come as standard on 1.8T's
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,106
    All turbo cars have DVs!
    Mar 2004
    238
    are they recirculating then rather than atmospheric?
    tennisguy's Avatar
    Dec 2003
    Bangkok
    82
    Yes it is recirculate. If it is atmospheric (some of them are from aftermarket), then your car will lose power.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,106
    Audi's have recirculating valves. DV in this case meaning Diverter Valve rather than Dump Valve.
    A couple of people on here are running asmospheric dump valves although it has been argued that it is not good for the car and therefore not recommended!
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    I only went to use "Mobil 1" engine oil as it was recommended by Forge to service their DV's.
    Will get some of the grease you guys mentioned and give that a try at the weekend...................cheers!
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Mike, the actual service instructions from Forge specify Mobil 1 Grease, which is either a typo by them or there is actually a Mobil 1 grease, but I don't know of one without looking on the web.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    May 2003
    South East
    116
    on my old S3, you could hear the air being released by the DV back into the airbox a lot more than the standard S3...
    This was due to when the garage replaced my wing and them not doing a proper job by refitting the sound proofing on the inner wing! [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Aug 2003
    Kingston, Surrey
    95
    Guys
    Had a look on the Mobil 1 site - indeed they do do a Mobil 1 Synthetic Universal Grease..
    [ QUOTE ]
    "....All Mobil 1 products, just like Mobil 1 motor oil, protect hardworking parts from temperature extremes, rust and wear. In fact, the same synthetic technology found in our motor oil is used in our fully synthetic grease.
    Mobil 1 Synthetic Universal Grease provides excellent protection against rust, corrosion and water washout. It's suited for wheel bearings, ball joint suspensions, steering linkages, and king pin and chassis lube points.
    Benefits:
    Excellent resistance to rust and corrosion.
    Good shock-loading protection.
    Excellent resistance to water washout.
    Outstanding lubrication over a wide temperature range.
    Applications: Recommended for automotive applications at both high and low temperatures. It will provide outstanding protection where moisture or condensation are factors...."
    [/ QUOTE ]
    Here's a link to the Product Data Sheet for Mobil 1 Grease
    Tone [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    Tone, thx for looking Dude [img]/ubbthreads/images/graemlins/grin.gif[/img]
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Saved me a job [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    PaulRS3's Avatar
    UK
    1,005
    WAK on the TT forums has some of this Mobil 1 grease in tubes for sale.
    NOT cheap mind you. He could only source it from US and got stung by vat/customs.
