Guys
Had a look on the Mobil 1 site - indeed they do do a Mobil 1 Synthetic Universal Grease..
[ QUOTE ]
"....All Mobil 1 products, just like Mobil 1 motor oil, protect hardworking parts from temperature extremes, rust and wear. In fact, the same synthetic technology found in our motor oil is used in our fully synthetic grease.
Mobil 1 Synthetic Universal Grease provides excellent protection against rust, corrosion and water washout. It's suited for wheel bearings, ball joint suspensions, steering linkages, and king pin and chassis lube points.
Benefits:
Excellent resistance to rust and corrosion.
Good shock-loading protection.
Excellent resistance to water washout.
Outstanding lubrication over a wide temperature range.
Applications: Recommended for automotive applications at both high and low temperatures. It will provide outstanding protection where moisture or condensation are factors...."
[/ QUOTE ]
Here's a link to the
Product Data Sheet for Mobil 1 Grease
Tone /ubbthreads/images/graemlins/beerchug.gif
