S3 Front Suspension Diagram/Schematic please
jonS3
NULL
Hi,
does anyone have a Schematic or Diagram for the front suspension set-up of an S3 (prefacelift if it makes any difference)
cheers
Jon
track control arm / front / quattro
suspension / wheel bearing housing / track control arm / front / quattro:
/ AQA,AJQ; S3:APY,AMK, AUL 1 1J0407151B
track control arm
/ quattro (1) 8N0407151D
track control arm / also use:
left >>8L-Y-117500 8N0 407 152 D / S3 (1) 8N0407152D
right >>8L-Y-117500 8N0 407 151 D / S3 2 1J0407175
lock plate
/ quattro 3 1J0407181
bonded rubber mounting
rear / quattro 3 1J0407181
bonded rubber mounting / F >> 8L-Y-117 500*
rear / S3 (3) 8N0407181B
bonded rubber mounting / F 8L-Y-117 501>>*
rear / S3 4 357407182
front / quattro 4 357407182
front / S3 (4) 8N0407182A
front / S3 5 N 90484003
hexagonal head bolt
M12X1,5X82 / 6 N 10262201
hexagon head bolt c/w shoulder
BM12X1,5X70 / 7 N 0150814
hexagon nut, shouldered
M12X1,5 / 8A 1J0407255AH
left / quattro (8A) 1J0407256AH
right / quattro (8A) 8N0407255E
left / S3 (8A) 8N0407256E
right / S3 9 N 10207803
hexagonal head bolt
M12X1,5X78 / 10 N 10106402
shouldered hex. nut, self-locking
M12X1,5 / 11 1J0407365C
guide joint
left / quattro (11) 1J0407366C
guide joint
right / quattro 11A 8N0407365B
guide joint
/ S3 12 N 90808801
M12X1,5 / 13 N 10127706
M8X26 / quattro 13A N 10332001
M10 / S3 14 1J0407613G
wheel hub with rotor
5/100 / quattro (14) 8N0407613A
wheel hub with rotor / see workshop manual
5/100 / S3 15 1J0411105AE
coil spring / 1 paint mark / 2 paint marks
violet white / quattro: PR-1GJ/J12; PR-1GF/V84; PR-G42/L29 (15) 1J0411105
coil spring / 1 paint mark / 4 paint marks
green blue / quattro: PR-1GJ/U38; PR-1GF/V83; PR-G42/L05 (15) 1J0411105C
coil spring / 2 paint marks / 2 paint marks
green blue / quattro: PR-1GJ/U39; PR-1GF/V85; PR-G42/L09 (15) 1J0411105BK
violet pink / quattro: PR-1GJ/U71; PR-1GF/V86; PR-G42/L10 (15) 1J0411105AG
violet yellow / quattro: PR-G42/L11 (15) 1J0411105AJ
coil spring / for sports-type running gear / 1 paint mark / 4 paint marks
violet yellow / quattro: PR-1GL/J22; PR-1GK/V51; PR-1GX/V87; PR-G43/L13 (15) 1J0411105BF
coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 4 paint marks
violet green / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88 (15) 1J0411105AM
coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 2 paint marks
violet pink / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88; PR-G43/L19 (15) 1J0411105BE
coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 3 paint marks
violet green / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89 (15) 1J0411105AL
coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 1 paint mark
violet pink / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89; PR-G43/L21 (15) 1J0411105CE
coil spring / for sports-type running gear / 2 paint marks / 3 paint marks
blue white / quattro: PR-G43/L08 (15) 1J0411105AT
coil spring / for models with heavy duty suspension / 1 paint mark / 4 paint marks
violet white / quattro: PR-G89/X29; PR-G89/Q29; PR-G89/L23 (15) 1J0411105AS
coil spring / for models with heavy duty suspension / 1 paint mark / 3 paint marks
violet white / quattro: PR-G89/X30; PR-G89/Q30; PR-G89/L22 (15) 1J0411105BH
coil spring / for models with heavy duty suspension / 2 paint marks / 2 paint marks
violet yellow / quattro: PR-G89/X31; PR-G89/Q31; PR-G89/L16 (15) 1J0411105BG
coil spring / for models with heavy duty suspension / 2 paint marks / 1 paint mark
violet yellow / quattro: PR-G89/X32; PR-G89/Q32; PR-G89/L20 (15) 1J0411105AF
coil spring / for models with heavy duty suspension / 1 paint mark / 1 paint mark
violet yellow / quattro: PR-G89/X33; PR-G89/Q33; PR-G89/L06 (15) 1J0411105AH
coil spring / 1 paint mark / 3 paint marks
violet yellow / S3: PR-1GQ/U85; PR-1GS/U85; PR-G21/L12 15 1J0411105AJ
violet yellow / S3: PR-1GQ/U86; PR-1GS/U86; PR-G21/L13 15 1J0411105BF
coil spring / F >> 8L-Y-110 000* / 1 paint mark / 4 paint marks
violet green / S3: PR-1GQ/U87; PR-1GS/U87 (15) 1J0411105AM
coil spring / F 8L-Y-110 001>>* / 1 paint mark / 2 paint marks
violet pink / S3: PR-1GQ/U87; PR-1GS/U87; PR-G21/L19 (15) 1J0411105BE
coil spring / F >> 8L-Y-110 000* / 1 paint mark / 3 paint marks
violet green / S3: PR-1GQ/U88; PR-1GS/U88 (15) 1J0411105AL
coil spring / F 8L-Y-110 001>>* / 1 paint mark / 1 paint mark
violet pink / S3: PR-1GQ/U88; PR-1GS/U88; PR-G21/L21 16 1J0411305B
stabilizer / F >> 8L-X-140 000*
21MM / PR-0AL: quattro (16A) 1J0411305AD
stabilizer / also use:
19MM 1J0 411 413 S / PR-0AR: quattro (16A) 1J0411305AD
19MM 1J0 411 314 S / PR-0AN:S3 17 1J0411314R
rubber mounting / F >> 8L-X-140 000* / for stabiliser:
19MM 1J0 411 305 B / PR-0AL: quattro 17A 1J0411314P
rubber mounting / F 8L-X-140 001>>* / for stabiliser:
20MM 1J0 411 305 L / PR-0AR: quattro (17A) 1J0411314P
rubber mounting / F 8L-Y-142 001>>* / for stabiliser:
20MM 1J0 411 305 AA / PR-0AN:S3 (17A) 1J0411314R
rubber mounting / for stabiliser:
19MM 8N0 411 305 A 1J0 411 305 G 1J0 411 305 AA / PR-0AN:S3 (17A) 1J0411314S
17MM 1J0 411 305 AD / PR-0AN:S3 18 1J0411315C
connecting link / F >> 8L-X-140 000*
/ PR-0AL: quattro 18A 1J0411315D
connecting link / F 8L-X-140 001>>*
left / PR-0AR: quattro (18A) 1J0411316D
right / PR-0AR: quattro 18A 1J0411315D
connecting link
left / PR-0AN:S3 (18A) 1J0411316D
connecting link
right / PR-0AN:S3 19 1J0411323A
bearing pin / F >> 8L-X-140 000*
/ PR-0AL: quattro 20 1J0411325B
bearing tube / F >> 8L-X-140 000*
/ PR-0AL: quattro 21 1J0411327
/ PR-0AL: quattro 22 1J0411336D
pipe clip / F >> 8L-Y-045 000*
/ PR-0AR,0AL: quattro 22 1J0411336D
pipe clip / F 8L-Y-045 001>>*
/ PR-0AR/G0G: quattro 22 1J0411336D
/ PR-0AR/G0L, G0N: quattro 22A 8N0411335A
/ PR-0AR/G0L, G0N: quattro 22 1J0411336D
/ PR-0AN:S3 22 1J0411336D
/ PR-0AN:S3 22A 8N0411335A
/ PR-0AN:S3 23 N 10101603
hexagonal head bolt
M8X18 / 24 1J0412249
axial grooved ball bearing
/ 25 1H0412303B
rubber stop for shock absorber
/ PR-1GF,1GJ, G42 25 1H0412303B
rubber stop for shock absorber / for models with heavy duty suspension
/ PR-G89 25 1J0412303
/ PR-1GK,1GL, 1GX,1GQ,1GS, G43 26 1J0412319C
limit stop
/ 27 N 90353603
hexagon nut, self-locking
AM14X1,5 / 28 1J0412331C
suspension strut storage
/ 29 357412341A
spring disc
upper / 30 1H0412365A
threaded bush
M14X1,5 / 31 1J0413031P
shock absorber / F >> 8L-X-140 000*
/ PR-1GJ: quattro 31A 1J0413031BK
shock absorber / F 8L-X-140 001>>*
/ PR-1GF,G42: quattro (31) 1J0413031R
/ PR-1GK,1GL: quattro (31A) 1J0413031BL
shock absorber / F 8L-X-140 001>> 8L-Y-129 000* / for sports-type running gear
/ PR-1GX: quattro (31A) 1J0413031CQ
shock absorber / F 8L-Y-129 001>>* / for sports-type running gear
/ PR-G43: quattro (31A) 1J0413031DB
/ PR-G89: quattro 31A 8N0413031D
shock absorber / F >> 8L-X-062 000*
/ PR-1GQ,1GS: S3 (31A) 8N0413031H
shock absorber / F 8L-X-062 001>> 8L-Y-129 000*
/ PR-1GQ,1GS: S3 (31A) 8N0413031G
/ PR-G21:S3 32 357413175A
bellows
/ (33) N 0151002
hexagonal nut / F >> 8L-X-140 000*
M10 / PR-0AL: quattro 33A N 0150814
hexagon nut, shouldered / F 8L-X-140 001>>*
M12X1,5 / PR-0AR: quattro 33A N 0150814
M12X1,5 / PR-0AN:S3 34 N 10417601
hexagonal head bolt / F >> 8L-X-140 000*
M10X50 / PR-0AL: quattro 35 N 90663201
securing ring
74X2 / 36 N 90587602
12 point socket shouldered nut self-locking
M20X1,5 / 37 N 90321302
M12X1,5 / 38 1J0498625
wheel bearing with mounting parts / comprising:
/ 40 1J0412311
distance piece / for models with heavy duty suspension
/ PR-G89 41 1H0412365A
threaded bush
M14X1,5 / 42 1J0412359
cap / F 8L-X-042 001>>*
/ 43 G 052735A2
it certainly does, thanks
I'm looking to change my top mounts, and want to see what else is worth changing at the same time
i've come up with top mount, bearing, and bump stops so far...
