track control arm / front / quattro
suspension / wheel bearing housing / track control arm / front / quattro:
/ AQA,AJQ; S3:APY,AMK, AUL
1 1J0407151B
track control arm
/ quattro
(1) 8N0407151D
track control arm / also use:
left >>8L-Y-117500 8N0 407 152 D / S3
(1) 8N0407152D
right >>8L-Y-117500 8N0 407 151 D / S3
2 1J0407175
lock plate
/ quattro
3 1J0407181
bonded rubber mounting
rear / quattro
3 1J0407181
bonded rubber mounting / F >> 8L-Y-117 500*
rear / S3
(3) 8N0407181B
bonded rubber mounting / F 8L-Y-117 501>>*
rear / S3
4 357407182
front / quattro
4 357407182
front / S3
(4) 8N0407182A
front / S3
5 N 90484003
hexagonal head bolt
M12X1,5X82 /
6 N 10262201
hexagon head bolt c/w shoulder
BM12X1,5X70 /
7 N 0150814
hexagon nut, shouldered
M12X1,5 /
8A 1J0407255AH
left / quattro
(8A) 1J0407256AH
right / quattro
(8A) 8N0407255E
left / S3
(8A) 8N0407256E
right / S3
9 N 10207803
hexagonal head bolt
M12X1,5X78 /
10 N 10106402
shouldered hex. nut, self-locking
M12X1,5 /
11 1J0407365C
guide joint
left / quattro
(11) 1J0407366C
guide joint
right / quattro
11A 8N0407365B
guide joint
/ S3
12 N 90808801
M12X1,5 /
13 N 10127706
M8X26 / quattro
13A N 10332001
M10 / S3
14 1J0407613G
wheel hub with rotor
5/100 / quattro
(14) 8N0407613A
wheel hub with rotor / see workshop manual
5/100 / S3
15 1J0411105AE
coil spring / 1 paint mark / 2 paint marks
violet white / quattro: PR-1GJ/J12; PR-1GF/V84; PR-G42/L29
(15) 1J0411105
coil spring / 1 paint mark / 4 paint marks
green blue / quattro: PR-1GJ/U38; PR-1GF/V83; PR-G42/L05
(15) 1J0411105C
coil spring / 2 paint marks / 2 paint marks
green blue / quattro: PR-1GJ/U39; PR-1GF/V85; PR-G42/L09
(15) 1J0411105BK
violet pink / quattro: PR-1GJ/U71; PR-1GF/V86; PR-G42/L10
(15) 1J0411105AG
violet yellow / quattro: PR-G42/L11
(15) 1J0411105AJ
coil spring / for sports-type running gear / 1 paint mark / 4 paint marks
violet yellow / quattro: PR-1GL/J22; PR-1GK/V51; PR-1GX/V87; PR-G43/L13
(15) 1J0411105BF
coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 4 paint marks
violet green / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88
(15) 1J0411105AM
coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 2 paint marks
violet pink / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88; PR-G43/L19
(15) 1J0411105BE
coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 3 paint marks
violet green / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89
(15) 1J0411105AL
coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 1 paint mark
violet pink / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89; PR-G43/L21
(15) 1J0411105CE
coil spring / for sports-type running gear / 2 paint marks / 3 paint marks
blue white / quattro: PR-G43/L08
(15) 1J0411105AT
coil spring / for models with heavy duty suspension / 1 paint mark / 4 paint marks
violet white / quattro: PR-G89/X29; PR-G89/Q29; PR-G89/L23
(15) 1J0411105AS
coil spring / for models with heavy duty suspension / 1 paint mark / 3 paint marks
violet white / quattro: PR-G89/X30; PR-G89/Q30; PR-G89/L22
(15) 1J0411105BH
coil spring / for models with heavy duty suspension / 2 paint marks / 2 paint marks
violet yellow / quattro: PR-G89/X31; PR-G89/Q31; PR-G89/L16
(15) 1J0411105BG
coil spring / for models with heavy duty suspension / 2 paint marks / 1 paint mark
violet yellow / quattro: PR-G89/X32; PR-G89/Q32; PR-G89/L20
(15) 1J0411105AF
coil spring / for models with heavy duty suspension / 1 paint mark / 1 paint mark
violet yellow / quattro: PR-G89/X33; PR-G89/Q33; PR-G89/L06
(15) 1J0411105AH
coil spring / 1 paint mark / 3 paint marks
violet yellow / S3: PR-1GQ/U85; PR-1GS/U85; PR-G21/L12
15 1J0411105AJ
violet yellow / S3: PR-1GQ/U86; PR-1GS/U86; PR-G21/L13
15 1J0411105BF
coil spring / F >> 8L-Y-110 000* / 1 paint mark / 4 paint marks
violet green / S3: PR-1GQ/U87; PR-1GS/U87
(15) 1J0411105AM
coil spring / F 8L-Y-110 001>>* / 1 paint mark / 2 paint marks
violet pink / S3: PR-1GQ/U87; PR-1GS/U87; PR-G21/L19
(15) 1J0411105BE
coil spring / F >> 8L-Y-110 000* / 1 paint mark / 3 paint marks
violet green / S3: PR-1GQ/U88; PR-1GS/U88
(15) 1J0411105AL
coil spring / F 8L-Y-110 001>>* / 1 paint mark / 1 paint mark
violet pink / S3: PR-1GQ/U88; PR-1GS/U88; PR-G21/L21
16 1J0411305B
stabilizer / F >> 8L-X-140 000*
21MM / PR-0AL: quattro
(16A) 1J0411305AD
stabilizer / also use:
19MM 1J0 411 413 S / PR-0AR: quattro
(16A) 1J0411305AD
19MM 1J0 411 314 S / PR-0AN:S3
17 1J0411314R
rubber mounting / F >> 8L-X-140 000* / for stabiliser:
19MM 1J0 411 305 B / PR-0AL: quattro
17A 1J0411314P
rubber mounting / F 8L-X-140 001>>* / for stabiliser:
20MM 1J0 411 305 L / PR-0AR: quattro
(17A) 1J0411314P
rubber mounting / F 8L-Y-142 001>>* / for stabiliser:
20MM 1J0 411 305 AA / PR-0AN:S3
(17A) 1J0411314R
rubber mounting / for stabiliser:
19MM 8N0 411 305 A 1J0 411 305 G 1J0 411 305 AA / PR-0AN:S3
(17A) 1J0411314S
17MM 1J0 411 305 AD / PR-0AN:S3
18 1J0411315C
connecting link / F >> 8L-X-140 000*
/ PR-0AL: quattro
18A 1J0411315D
connecting link / F 8L-X-140 001>>*
left / PR-0AR: quattro
(18A) 1J0411316D
right / PR-0AR: quattro
18A 1J0411315D
connecting link
left / PR-0AN:S3
(18A) 1J0411316D
connecting link
right / PR-0AN:S3
19 1J0411323A
bearing pin / F >> 8L-X-140 000*
/ PR-0AL: quattro
20 1J0411325B
bearing tube / F >> 8L-X-140 000*
/ PR-0AL: quattro
21 1J0411327
/ PR-0AL: quattro
22 1J0411336D
pipe clip / F >> 8L-Y-045 000*
/ PR-0AR,0AL: quattro
22 1J0411336D
pipe clip / F 8L-Y-045 001>>*
/ PR-0AR/G0G: quattro
22 1J0411336D
/ PR-0AR/G0L, G0N: quattro
22A 8N0411335A
22 1J0411336D
/ PR-0AN:S3
22 1J0411336D
/ PR-0AN:S3
22A 8N0411335A
/ PR-0AN:S3
23 N 10101603
hexagonal head bolt
M8X18 /
24 1J0412249
axial grooved ball bearing
25 1H0412303B
rubber stop for shock absorber
/ PR-1GF,1GJ, G42
25 1H0412303B
rubber stop for shock absorber / for models with heavy duty suspension
/ PR-G89
25 1J0412303
/ PR-1GK,1GL, 1GX,1GQ,1GS, G43
26 1J0412319C
limit stop
27 N 90353603
hexagon nut, self-locking
AM14X1,5 /
28 1J0412331C
suspension strut storage
29 357412341A
spring disc
upper /
30 1H0412365A
threaded bush
M14X1,5 /
31 1J0413031P
shock absorber / F >> 8L-X-140 000*
/ PR-1GJ: quattro
31A 1J0413031BK
shock absorber / F 8L-X-140 001>>*
/ PR-1GF,G42: quattro
(31) 1J0413031R
/ PR-1GK,1GL: quattro
(31A) 1J0413031BL
shock absorber / F 8L-X-140 001>> 8L-Y-129 000* / for sports-type running gear
/ PR-1GX: quattro
(31A) 1J0413031CQ
shock absorber / F 8L-Y-129 001>>* / for sports-type running gear
/ PR-G43: quattro
(31A) 1J0413031DB
/ PR-G89: quattro
31A 8N0413031D
shock absorber / F >> 8L-X-062 000*
/ PR-1GQ,1GS: S3
(31A) 8N0413031H
shock absorber / F 8L-X-062 001>> 8L-Y-129 000*
/ PR-1GQ,1GS: S3
(31A) 8N0413031G
/ PR-G21:S3
32 357413175A
bellows
(33) N 0151002
hexagonal nut / F >> 8L-X-140 000*
M10 / PR-0AL: quattro
33A N 0150814
hexagon nut, shouldered / F 8L-X-140 001>>*
M12X1,5 / PR-0AR: quattro
33A N 0150814
M12X1,5 / PR-0AN:S3
34 N 10417601
hexagonal head bolt / F >> 8L-X-140 000*
M10X50 / PR-0AL: quattro
35 N 90663201
securing ring
74X2 /
36 N 90587602
12 point socket shouldered nut self-locking
M20X1,5 /
37 N 90321302
M12X1,5 /
38 1J0498625
wheel bearing with mounting parts / comprising:
40 1J0412311
distance piece / for models with heavy duty suspension
/ PR-G89
41 1H0412365A
threaded bush
M14X1,5 /
42 1J0412359
cap / F 8L-X-042 001>>*
43 G 052735A2
