AH FabricationsChris Nott
    TanyaS3's Avatar
    May 2003
    UK
    205
    Changing my battery - help please
    Hello
    Hope everyone had a good xmas and new year.
    So I have a new battery for the S3 but how the hell do I get the old one out! Looks like the hardest battery to change ever
    Any help would be appreciated
    thanks
    Tanya
    edward_harris's Avatar
    s3 gone now a shiney red evo 6
    Jan 2007
    berkshire, Reading
    1,062
    its not hard really you need to take one bracket off from memory, then i think there is a case with all a few wires going in to it, take that off which is connected to the + then take off the -!! then it should come out!
    Xbox online id - supaed133
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    unscrew plastic cover - you can now see battery
    unclip loom from both sides of battery and lift away from you - you can now access battery, remove connections from terminals.
    get a 13mm (i think) socket and undo retaining clamp, lift out and replace.
    remember to set your one touch windows for full closure by opening and closing them fully and then removing key from ignition.
    that should be it
    S3(225) - Dolpin Grey | Leather/Silver Alcantara | Bose | ViperDV | Samco Hoses | Eibach Pro-Kit | H&R Spacers | Brembo GT kit | AreoWipers | BlueTooth | Dension Icelink | New engine, Clutch, Turbo, Water pump thanks to Cambelt @ 79,000 miles | New short engine thanks to ****ed valve 22,000 miles later!
    TanyaS3's Avatar
    May 2003
    UK
    205
    thank you, I will follow those instuctions
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    yep, incase you haven't done it already, you just need a 10mm socket for the battery terminals and a 13mm socket to reach the plate that holds the battery down (front side) middle of battery.
    Depending on which battery you got it might only just fit, but you should be able to reuse most / all the covers and plate that holds the fuses and connections will clip back onto most batteries.
