EM TuningAH Fabrications
Results 1 to 9 of 9
    Jun 2007
    446
    5speed quattro box
    does any one know how strong a 5speed quattro box is?
    the one on my A3 has just gone over 100k miles, be pushing my luck with it if i go ihi?
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    I would say the box is essentially the same as the one you had in your Golf? O2J ?
    The diff is the weak point.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    Jun 2007
    446
    yea o2j was in golf. how can i find g/boz code on my car?
    AJQ engine if that makes any difference.
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    It will be in your documentation somewhere if you have all the originals or I think it's on some bar code sticker, in the boot?
    Sorry for being a bit vague there but i DO remember seeing it on the documentation of mine.
    Clicky Here!
    Jun 2007
    446
    i think it's on v5, but i havnt got mine through yet.
    i'll go check in the boot once rains finished
    Oct 2007
    Norwich
    55
    I have the same car with the AJQ engine, gearbox code on mine is EUK DXW, so probably the same I would imagine. Mines in the service book first page, should have all the codes there!
    Jun 2007
    446
    not a o2j then?
    Jun 2007
    446
    yep, my boot sticker does say the same.
    on another note, offerd up 1 of the same size tyres i'll be running on new alloys. only 225 45 17, but looks tight in archs already. worried bout lowering 40mm
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    951
    I swapped mine for a 6 spd when the clutch needed changing ,6spd has larger clutch and ratios are better,the revs in 5th on the 5spd seemed very high and felt like it was holding max speed back?I was lucky to find a very low miles 6spd box very cheap 350 ish and the clutch was like brand new,to do this swap you will need 6spd flywheel ,clutch and starter motor as well as box.6spd boxes are supposed to be stronger.Mine is also AJQ,ish,Cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
