EM TuningSky Insurance
    Badgeronimous's Avatar
    Aug 2005
    Beith, Ayrshire
    16
    01413 Lateral Acceleration Sensor G200
    It appears I have a fault with this, which is probably why my ESP isn't working :P
    Anyway, how hard is this to replace on an '01 S3, and where can I find the spare part online, or will I need to go to a dealer.
    Feb 2007
    81
    its an easy swap, the hard part is finding where it is, plus im not sure if it will need recallibarating once done, do a search on the site for lateral and g200,
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    It is a DIY job - it is mounted underneath the steering column. You need to remove the lower dash surround on the drivers side and then you should see it on an L shaped bracked along with the other sensor (Longitudinal). Expect to scrape your knuckles to bits getting it off! It costs approx 90 and as far as I'm aware, is an stealer only part.
    There is definitely a guide on here if you search - I followed it when I replaced mine earlier in the year.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Feb 2007
    81
    any luck?
