Sky InsuranceVolks Autos
Results 1 to 9 of 9
Thread: Fault codes
    RS4 B5 380bhp
    Feb 2007
    549
    Fault codes
    Hi everyone,
    I ran VAGcom and got the following:
    Address 01: Engine
    Controller: 8D0 907 551 K
    Component: 2.7l V6/5VT G 0001
    Coding: 10711
    Shop #: WSC 06435
    WUAZZZ8DZ1N901949 AUZ7Z0Y1578245
    1 Fault Found:
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8D0 907 389 E
    Component: ABS/ESP allrad D56
    Coding: 04395
    Shop #: WSC 00899
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    Thanks in advance
    Kind Regards
    Nick
    jesters3's Avatar
    The Shire's
    1,516
    16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
    • Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
    • Evaporative Emission (EVAP) Canister Sealing faulty
    • Pipes between Tank Breathing and Throttle Body leaky/blocked
    Possible Solutions
    • Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
      • Perform Output Test
    • Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
      • Perform Basic Setting
    • Check Pipes between Tank Breathing and Throttle Body #
    01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
    Possible Symptoms
    Possible Causes
    • Basic Setting not performed
    Possible Solutions
    01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    Possible Causes
    • Brake Pedal Switch (F) faulty/jammed
    • Brake Pressure Sensor 1 (G201) faulty
    Possible Solutions
    • Check/Replace Brake Pedal Switch (F)
      • See Measuring Blocks
    • Check/Replace Brake Pressure Sensor 1 (G201)
      • ABS Hydraulic Unit (N55) may need to replaced
      • Perform Brake Pump Bleeding
      • Perform Brake Pressure Sensor 1 (G201) Basic Setting
      • Replace Brake Electronics Control Module (J104)
    Retrieved from "http://wiki.ross-tech.com/index.php/01435"
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    RS4 B5 380bhp
    Feb 2007
    549
    Thanks Jesters3, I will check and report back.
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    Hi Nickelvery - did you come to a solution for the EVAP code?
    the same one has cropped up on my S3 this week.
    S3 is gone
    jesters3's Avatar
    The Shire's
    1,516
    Do you have any issues with your fuel flap? i.e you get a hissing sound of the pressure being released when undoing the the fuel cap?
    Jester
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    nope i dont get any noise when opening the fuel flap.
    what would that indicate out of interest?
    S3 is gone
    jesters3's Avatar
    The Shire's
    1,516
    It would indicate a buggered gravity valve in the fuel tank, meaning a fuel tank off job to get to it.
    But you haven't got that so all is good!!
    On the EVAP issue, have a look around the canister to see if any leakages are there.
    Jester
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    certainly will do.
    ..... erm wheres it located?!
    you needing an RS3 badge by the way - just noticed your sig and I've got one kicking around the garage thats still in the packet
    S3 is gone
    jesters3's Avatar
    The Shire's
    1,516
    Next to the Power Steering Fluid container it has the hoses coming out of it.
    Unforunately not as I haven't got an RS3 yet and I doubt I ever will, then again you never know!
    Jester
