Little update. I've now added a Walbro fuel pump. Mounted it under the car rather than in the engine bay like some. I'm still trying to keep the bay as OEM as possible.
Also decided to buy a new turbo. My car still isn't boosting right. Most of the time it will be okay, but the odd time it will overboost as before. I've been though everything and the people I've spoken to all suggest boost creep or a cracked turbine housing. Whatever is up, its whistling above 22psi and I need to keep watching the boost gauge. Can't reliably boot it.
So in the search for a better unit I grabbed a TD05H-18G hybrid. It's a Blouch item sourced through Scooby Clinic. Has the stronger 14psi (1bar) actuator and a ported turbine housing to hopefully eliminate all boost creep.
It's a bolt on replacement for the subaru engine so the compressor and turbine housing are oriented differently to how I need them. So I decided to rotate the housings to suit the 1.8T (some people call it "clocking").
As it came:
18G vs K03
Oil and water fitting removed.
After removing a large circlip for the compressor housing, the clamp ring for the turbine housing and the actuator it was possible to slide off the housings and remove the CHRA.
No balancing is required if the CHRA is left untouched as I have done.
Turbo disassembled:
Subaru turbos have a pin inserted into the turbine housing that locates with a hole in the CHRA for correct orientation. Obviously I needed to remove this to re-orient for the 1.8T. Five minutes with the dremel was required to grind it flat.
View of the ported tubine inlet:
Then all that was required was to re-assemble.
Back together with housings pointing in the correct directions:
The turbo is now pretty much ready to go on but due to the modification I'll need to weld on a couple of bosses to bolt the actuator to (area circled in pic). Shouldn't be too difficult. Bought some aluminium offcuts off ebay for the job.
Not sure when I'll get stuck in fitting it. Going to do the engine work at the same time. I'm waiting on some machine shops to get back with prices on some head work. Mainly fitting the new valve guides. If anyone knows of a good place in the south, then let me know.
