Badger5EM Tuning
Results 1 to 8 of 8
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Still have clutch problem, could be pedal broken or slave cylinder
    garage today replaced the master cylinder and the pedal still stays down
    they think its now the slave cylinder which needs replacing,
    audi are charging 47 plus vat for the slave and a garage is charging for 2 hours labour,
    does that sound right ?
    Also the garage said the pedal might be broken, This is a TT common fault but has it happened to anyone with a A3/S3 ?
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    Jan 2007
    Hertfordshire
    520
    Happened to me, best advice I can give is check around yourself, I got ripped off because I didnt know what was wrong. Now I do, it cost me 350 to learn that but I do.
    If the pedal box is broken (a common fault apparantly) check to see if any plastic is lying on the floor of the footwell, if so then its a hell of a lot cheaper than a new clutch, if your garage replaced the Master Cylinder and it didnt rectify the problem then it sounds like they dont have a clue and will keep replacing parts until its fixed, get a second opinion.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    cheers for the reply
    yeah the garage didnt seem like they had a idea what they were doing
    to mo ill take it to a specialist and he said he will check if the pedal is broken
    what did the plastic bit look like which was broken ?
    Still need Remap
    2007 Audi S3 8L
    Jan 2007
    Hertfordshire
    520
    White clip but it was in bits in the footwell, so just check for plastic in the footwell, if your anything like me it wont be too dirty so should be easy to spot.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    100% i didnt see any white plastic bits on the floor
    the tt forum thinks it might be something to do with bleeding, thats its not bled properly
    Still need Remap
    2007 Audi S3 8L
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I've not experienced a broken pedal, but get your head under there to see if the push rod is still moving correctly. If it is then it'll be pushing fluid.
    Bleeding the system is very simple. Simple single line from the master to slave, but I guess if there is air in there, it would cause a prob.
    When my slave went, the pedal did stick to the floor like yours is.
    The slave on the S3 is a gearbox off job, so I think the offer of 2 hours labour will be a misquote unfortunately.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    i swear its doing my head in,
    HTC to bleed the system, is the bleed valve under the battery but alot lower down if that makes sense,
    Still need Remap
    2007 Audi S3 8L
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I can fully believe that!
    Yeah bleed nipple is in that area. Its on the bell housing. Follow the bendy hard clutch line in the area of the gear cables. It'll lead to it.
    Process for bleeding require a pressure bleeder like the ones that run from a spare wheel. From the manual:
    ‒ Switch on bleeding appliance.
    ‒ Working pressure 2.0 bar
    ‒ Open bleed valve.
    ‒ Bleed off approx. 100 cm3 of brake fluid.
    ‒ Close bleed valve.
    ‒ Rapidly operate pedal 15 times from stop to stop.
    ‒ Bleed off a further 50 cm3 of brake fluid.
    ‒ Close bleed screw (tightening torque 4.5 Nm).
    ‒ Detach filling appliance from brake fluid reservoir.
    ‒ Press clutch pedal several times following completion of bleeding process.
    ‒ Bleed system again if necessary.
