Ess_Three said:and the standard airbox won't raise the risk of killing the MAF sensor.
Ess_Three said:and if it's an open cone, worse running in traffic or on a hot day.
james0808 said:I think both will be slightly better than the standard airbox but you wont notice any difference apart from extra noise and you wont have to keep replacing it.
Neither will a cone filter.
Ess_Three said:Depends what you mean by 'better'
From a filtration point of view, standard is better than any foam or cotton type - when clean.
Although the makers will tell you otherwise.
A cone filter can screw up a MAF, if the filter is heavily oiled...which some are....but so are some panel filters!
There is no conclusive proof that oiled filters 'kill' MAfs, but a coating of oil can change the electrical readings...so it does affect it to some degree.
A standard paper filter doesn't.
From a power gain point of view, you'll be lucky to get any gain. Maybe a couple of BHP from a decent panel filter and a modified airbox...and none of the hot running issues you get with a cone...so that would still be my route of choice.
You pays yer money and makes yer choice.
Do you still use all the standard pipes going to the airbox?simch said:Induction kits on 1.8T are absolute waste of money! If yours is a 1.8 without turbo I'd say dont bother either!
Mine runs 350hp on stock box and paper filter, and many run over 400 on it.
Spend your cash on some decent tyres or put toward a suspension kit is my advice! You will get far more peformance increase than you will ever with an induction kit...!>
james0808 said:Better air flow than the standard airbox.
The route the air has to travel around the pipes and through the airbox before getting to the engine cant be better than straight through a pipe with hardly and restrictions and no sharp bends.
Ive been using oiled cone filters(some shielded and others away from the engine bay) for many years so none of the hot running issues and ive never had a problem with anything getting through the filter and damaging any part of any engine,so the filtration must be ok.
To get a coating of oil onto the maf the filter must be completely saturated with oil,and surely with the airflow the oil would be blown off the maf and into the engine.
Has anyone with a nacked maf ever took it off and actually seen a coating of filter oil on it,i know i havent and ive took loads out.
46TheDoctor said:Ive had 2 cars rolling roaded at k&n in warrington, in the process fitting cone filters, both cars actually lost power!!! However using the standard airbox with a performance air filter increased torque ever so slightly. DO NOT WASTE YOUR MONEY ON A CONE FILTER. The second time i had a car done it was my STI Type UK Impreza, the engineer told me that cone filters only give a bhp increase with turbocharged cars running upward of 350bhp.
james0808 said:When did i say anything about gaining power with a cone,i didnt.So why are you banging on about performance.
Less restrictions = better airlow,plain and simple,again nothing about power.
But they sound louder...so they must be better/faster though, eh?
Once again your talking complete **** about power gains.
At the end of the day...people should fit what they feel comfortable with...
I agree with you there.
AwesomeSarah said:We have rolling road tested a car with a standard and a Pipercross panel filter
It gained 4bhp
I tried a Pipercross induction kit on my Fabia and it gained 7bhp
Sarah
Ess_Three said:Well lets see...
'Tuning' is normally about making improvements...but since you choose to cherry-pick, lets me point out the more important bit:
A cone filter in the engine bay will suck in hot air and make your car slower.
Is that plain enough?
Sort of De-tuning.
Or tuning for Chavtastic fools.
What point is more airflow if it doesn't do you any good?
Especially if you make that extra air hot...so that the engine redards the timing and you loose power.
It's been proven time and time again...my me and many others...
It's nothing mythical...hot air = less power.
Simple physics, I'm afraid.
Not ****. Fact.
But you can choose to ignore it if you like...the reality is, an open cone as fitted to most induction kits will loose you power when the engine is hot and the bonnet is shut.
And since we don't all drive round with a big fan blowing on the front of the car, and the bonnet open (like you see on some dyno days) the power losses are very real, i'm afraid.
