Results 1 to 7 of 7
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    Possibly a dumbass brake question
    Hi all
    Had my front discs and pads replaced by a local garage last week and after driving 300 miles the pedal travel is still too long
    Previously it was right on the button - now I have to depress it quite a way. The brake function seems ok just dont want this amount of travel
    Ok so to the dumbass question, Does a brake disc and pad change require a brake fluid bleed ?- as if so perhaps that explains the extra pedal travel and maybe they didnt do it
    Would prefer to have some info / ammo before I call them to look at it
    If you aint first you're last
    Dec 2006
    190
    Normally you wouldnt change the brake fluid just becuase you was changing the discs and pads, no. Pedal travel is more likely to be something to do with the hydraulics not the friction.
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    Any ideas what they might have done ?
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Did they change the fluid?? If your not happy just pop back and ask them to bleed the brakes. Wouldn't take long and should resolve any travel.
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    Yeah thanks Dave
    I am going back anyway - just wanted to know what the issue was
    Jul 2007
    15
    Try bleeding yourself?
    Why don't you try bleeding them yourself? Do you have someone that can help you? Its real easy. Old school way, you and a mate open vlv and press pedel. SHUT before you depress the pedel all the way. There's a little more to it.... Or buy a pressure bleeder. They are pretty cool, or gravity bleed, which works. Search for info. Corvetteforum.com is very good for brake questions. They need better brakes. I also have one with killer brakes for a 1971 car.
    Carbster
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    don't forget in newer car you have to activate the ABS pump to bleed them properly! using vag com or such like.
    S3 - Gone but not forgotten!
