Badger5JMB Retrofits
Results 1 to 33 of 33
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    spluttering and dieing on cold start
    Went out to my car this morning, started it up and it was spluttering as if it was running on 2 cylinders and wouldnt stay alive without me revving the engine.
    After about 10 - 15 seconds of revving it ran by itself as if nothing was wrong, I have had this problem before but today was probably the worst.
    What is the most likely cause of this ?
    James
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Mine has been doing the same over the last couple of weeks. Not every morning but mainly when it is really cold. I also would like to know what the problem is. Think I'm going to have to buy VAG-Com
    rodenal's Avatar
    Oct 2006
    1,982
    my car does this every so often, it also wont rev above 5.5k revs when its like this, and sometimes hangs for a few seconds in low gears.
    Vag com reckons it's a camshaft position sensor, have checked the wiring as its only an intermittent fault but no joy.
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    I have never seen so much troubles with one car on cold mornings (outside french cars)...Is this a common a3/s3 fault...the fuel lines/sensors etc must be badly positioned or something?
    Jul 2005
    2,488
    the only common fault that could be related is coilpacks or temperature sensor.
    Of course, weaknesses in these parts will be highlighted by the extremes of temperatures that we see in autumn/winter months.
    darko's Avatar
    Dec 2004
    london, uk
    272
    my car also did the same this morning - 1st time i have experienced it and the car has been used in the alps at minus 22 before without problems, i was going to put a new set of plugs in to see if that helps as it also seems to have a rough idle at the moment
    Jul 2005
    2,488
    Personally. I cant see the plugs making a difference. When were they last replaced? If in doubt, take one out and have a look, it may save you £50.
    The problems you have both described are textbook signs of a failing coilpack that is not yet entirely kaput.
    It doesn't matter if your car has previously been running OK at -22 before, as the coilpacks were fine then.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quote Originally Posted by Aky
    I've got Vagcom and don't think I'm too far from you if you need a hand. I've recently replaced all my coilpacks due to failure.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    darko's Avatar
    Dec 2004
    london, uk
    272
    its true it could be a coil pack - i have one remaining "L" version the others have all been replaced with "R" which i think are the latest, plugs are old though so ill probably do both
    Dec 2006
    190
    i had the same problem, was told it could be coolant temp sensor or crank sensor. replaced coolent temp sensor first as it was cheapest and touch wood hasnt done it since (3wks+)
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    How does one test for a coil pack on its way out if the car only does this on a cold start ?
    Example I drove my car to work at 8am and it did it.
    It takes me 5 mins to get to work where it is then parked till 12:30
    then at 1:30 it is again parked up and not moved until 6pm and at 6pm it was colder than this morning it only does it very first thing in the morning.
    Jul 2005
    2,488
    get a dealer to scan the fault memory, or do it yourself with vag-com.
    It should say something like "multiple missfires on cylinder xx"
    Felon's Avatar
    Slightly odd.
    Oct 2007
    Chandler's Ford, Hampshire
    87
    My S3 has been doing this as well. When I do move away though it feels like the turbo isn't working. If I stop then start again, everything is normal. So, last night I dropped it into my local dealer so they could start it from cold this morning and figure out what the problem is. I'll post again once they come back to me. Personally, I don't think it's a coilpack issue - i've had a couple of them and it isn't the same...
    2002 Absolute Red (Tomato Soup colour) S3 Custom Code Phase 1 done 10th October 2007
    Jul 2005
    2,488
    Seriously, there are so many different reasons as to why it may be happening, but you're all talking about different situations and applying the same diagnosis.
    Some people are having problems when initially started, and others are having problems when driving (and maybe idle too).
    please somebody correct me if i'm speaking ********, but this is how i understand it:
    The engine has many maps, but they can be easily split into 2 types: idle and run maps. For the idle map, some different sensors/switches come into play to those used in the run map. Those used in idle are lambda's, camshaft sensor, coolant temperature sensor, n75
    Those used in a run map are lambda's, camshaft, knock, MAF, coolant, throttle position, clutch switch, DV, n75, intake temperature, etc etc.
    I'm out of my league try to explain and list all of the sensors and switches, but the point is that the idle map is a more simple one that has less to go wrong - but can still be affected by a good-old air-leak.
    To be honest and fair to everbody though, everything people have suggested in this thread COULD be the root cause of poor running problems, which is why the first thing people say is "what does vag-com say". Without vag-com, you just have to resort back to the old method of replacing the cheapest and most likely bits first - which are the coilpacks.
    rodenal's Avatar
    Oct 2006
    1,982
    Yeah i agree with madvw, that's why i mentioned vag com as my car has had many running/starting/spluttering issues, and it really isn't possible to tell from just a description on the internet.
    If nothing else vag com will at least give you some pointers as of where to start looking/checking
    Jul 2005
    2,488
    AWESOME! how i love the irony of fate....
    Just went out for a drive for the first time today, and guess what? yep.
    anyway, scanned it with vag-com (shareware 409 + gendan interface works OK with vista.... for those interested, drivers are picked up by windowsupdate...)
    aaaaand:
    1 Fault Found:
    17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
    P1296 - 35-10 - - - Intermittent
    anyway.. back from audi with a new coolant sensor and o-ring, parts for a BAM are:
    A059 919 501A - C3D1 Temperature Sensor
    AN 903 168 02 - C3D1 O-Ring
    24 +vat.
    and also the excellent how-to for a BAM engine:
    http://www.wak-tt.com/tempsensor/tempsensor.htm
    The moral.... dont listen to me....use vag-com
    Felon's Avatar
    Slightly odd.
    Oct 2007
    87
    Just heard back from the dealer.
    Firstly they were able to replicate the cold starting problem I was having - always a good thing...
    They mentioned 2 issues specifically:
    - the throttle body needs readapting so it is letting the correct amount of air through. On mine it has lost it's original settings and needs a good clean.
    - the thermostat needs replacing
    They're going to hang on to it overnight so they can check it again in the morning.
    Finger's crossed - but they seem confident...
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    mine also been doing this but if I rev it a little it goes away. Might have to track down someone with vaccom near me. or just change the sensor for 25 quid
    red to red black to black blue to bits
    Oct 2006
    Manchester
    724
    For the price of the exhaust , it may be worth fitting the sensor
    They are not that expensive and easily done
    Just make sure the engine is cold
    Sarah
    rodenal's Avatar
    Oct 2006
    1,982
    Hmm, defo check it first.
    No point in replacing things that arent broke, wether they're £25 or £250
    Felon's Avatar
    Slightly odd.
    Oct 2007
    87
    Following my note above, car started fine this morning and dealer confident that all now ok after fixing throttle body and replacing bust thermostat.
    Marvellous!!!!!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Mines doing the same and I have plugged it in and no fault code so Audi are having it on the 27th,coilpacks are covered by a five year warranty by Audi so get them to pay for them
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quote Originally Posted by fingermouse
    As mentioned to Aky, your welcome to use my copy of vagcom if you're near me.
    > S3 225 (03) - OEM+
    View: My S3 diary
    thats me
    Sep 2004
    west yorkshire
    3,762
    might have to have a mini meet up then cheers im in huddersfied area, if you can see emley moor tv mast then im not far from that lol
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I'm in littleborough, near J21 off the M62 so just a short hop really. I'd be up for the meet but the battery on my vagcom laptop is dodgy so I need a power source . I scanned Aky's earlier tonight though and it didn't turn up any obvious problems (i'll let Aky elaborate if he wants to!). I'm happy to do yours though if you want, it just means I can have a good nosey at your car as well (as I did with Aky's - and it sure is a nice motor!).
    > S3 225 (03) - OEM+
    View: My S3 diary
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    As Funky says I went round thinking I would be able to easily find out what the problem was. Nothing came up apart from Error code 17705 which I don't think will be anything to do with the car starting on 3 cylinders. Vag-Com/Ross Tech suggests checking out the N249 valve, check for boost leaks and possbily throttle body re-allignment. Cheers for taking the time to have a look. Pitty nothing conclusive. Hope you manage to twist the Mrs's arm into letting you get some new suspension.
  28. #27
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Quick scoot off topic:
    When I got in I ran the idea of new suspension, ARB's and brembo's by her....lets just say she wasn't as enthusiastic as me. No worries though, next time it goes in for a service, I'll make sure its an expensive one
    Back on topic:
    Good look with the hunt for the fault.
    > S3 225 (03) - OEM+
    View: My S3 diary
  29. #28
    thats me
    Sep 2004
    west yorkshire
    3,762
    cheers, just need to free up some time ..........
  30. #29
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    well i code read the engine and nothing came up apart froma code that hadn't been cleared from ages ago.
    there was something though, i *may* have a knackered O2 sensor could this cause the spluttering on a cold start ?
  31. #30
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    my cars been at the stealers since thursday,it has started boosting as well now.
    Whilst they have it I'm in their brand new A3 which is a nice change.
  32. #31
    darko's Avatar
    Dec 2004
    london, uk
    272
    i replaced my temparature sensor as per the guide here :
    no sign of the spluttering since and the car feels much better generally as a bonus !
  33. #32
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by darko
    yes they mentioned that,pick it up tomorrow after they check it starts okay,Waks is very good for info but I missed that one
  34. #33
    thats me
    Sep 2004
    west yorkshire
    3,762
    Just got a sensor from gsf , just under 20 quid all in. Guy there said ppl often change these every 10,000 miles if they do a lot of short runs it seems to kill them ??? . Suppose he will know more than me
