Volks AutosAH Fabrications
    Oct 2005
    uk
    264
    Spacers and ebay
    I'm going for 10mm and 15mm at the rear for my S3, I'm looking at these on ebay-Any good, to be avoided, go for a branded item?
    http://cgi.ebay.co.uk/15mm-Hubcentri...QQcmdZViewItem
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    they look like they are made from steel!
    most good spacers are a good quality aluminium,
    the coating on the steel which is now just been made illegal to coat any metal with it, its rubbish and if getting wet and warm they are going to be rusting within 6months!
    S3 - Gone but not forgotten!
    Oct 2005
    uk
    264
    Ok, thanks for that, always a catch, when you think something is too cheap. I'll keep on looking
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    german ebay is your best bet!
    just search H&R you'll find them
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    Quote Originally Posted by sitrials
    can you expand on this, i can't see any reference to coatings in the advert, i'd be interested to know what the coating is and why it's now illegal.
    in my opinion i'd rather go for a steel spacer because the weight of the car is sitting on the spigot, personally i wouldn't feel safe with all the suspension forces being contained by an ally spigot. i think ally is used because of the reduced weight making it less likely for you to get balancing issues
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    The weight of the car and all force 'should' be on the bolts, if it works as per a normal wheel mounting face.
    I wonder how much heavier the steel ones are?
    They might be OK depending on weight if you painted them to stop rust.
    <Insert meaningless geeky specs here>
