Chris NottVolks Autos
    Badgeronimous's Avatar
    Aug 2005
    Beith, Ayrshire
    16
    Vag-Com problem on a new laptop with vista
    Anytime I try to run vag com, I set it up then start running the auto check/scan facility (I can't seem to switch my traction control on so want to find out why), it starts the test then within 10 secs of it starting I get ''program has stopped working''
    I'm using version 409, with a third party cable (that does work as the guy I've borrowed it off uses it regularly), running Vista home edition on a brand new laptop. The car is an '01 S3.
    Aug 2005
    Beith, Ayrshire
    16
    Red face My S3 computer display is a bit fuzzy (horizotal lines).
    double post sorry
    Jun 2004
    Surrey
    595
    I had the same problem so I bought a real setup. I would borrow your friends laptop as there seems to be some USB driver problems with Vista.
    rodenal's Avatar
    Oct 2006
    1,982
    I would try it on an xp laptop, vista is the work of the devil lol
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    mavala's Avatar
    Oops!!!!
    Dec 2007
    Hereford
    39
    Only Vag Com 704.1 works with Vista.
    You will also need to replace the KKL cable with an HEX CAN USB cable
    May 2003
    Reading
    705
    I have a laptop running Vista using version 311 and a 3rd party cable seems to work fine
