Volks AutosSky Insurance
Results 1 to 7 of 7
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    Rear washer jet is weak
    Just a quick one, when i use my rear washer jet it dribbles out and hardly reaches the screen has anyone had this before ?
    Ive checked that the jet isnt blocked and there is plenty of water,could this be a kinked tube ?
    A4 TDI S-LINE
    jesters3's Avatar
    The Shire's
    1,516
    I had the exact same problem. Check out this thread by HTC. The cost of the repair kit was £21 ish from VAG Parts and was a doddle to fit.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Have you checked to make sure it isn't spraying into the boot. The pipe comes off the sprayer. I had my boot sensor replaced 4 times because water had shorted it out.
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    couldnt see any water in the boot,it is coming out of the washer jet but it dribbles out all prob get that repair kit,have you got the part number jester,
    Thanks for your replies i appreciate them
    A4 TDI S-LINE
    Apr 2007
    297
    Is it coming out ok in the front jets? If not, run hot water throught eh system and spray. Some cheaper windscreen wash (or no fluid at all!) gets real thick after a while and starts to resemble jelly...
    Feb 2004
    2,036
    Isn't there some filters on the washer bottle? Seperate for front and rear....?
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    fronts work fine,just the rear thats playing up,i know most washer bottle have gauze filters to stop crap getting throgh to the washers but didnt know the front and rear had individual filters,cheers again guys
    A4 TDI S-LINE
