AH FabricationsJMB Retrofits
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    FAO: People with retrofitted facelift headlamps (From Europe)
    Could anyone who purchased their lights from germany and used the lever inside the lights to change them from LHD to RHD please check to see if there was a lever in *BOTH* lights please? I only have one in the passenger side light and i need to get these lights through my MOT or i have no car to drive to work! Cheers
    Ross
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Anyone? If not what can i do, can i use tape or an "conversion kit" to modify the beam pattern? Cheers
    Ross
    Oct 2007
    2,597
    The tape masking option doesn't work on facelift headlamps. The beam pattern is formed by the parabolic reflector.
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Thanks Siena, is there any way i can adjust my lights myself (roughly) or do you need the device people in garages use?
    Futhermore, does anyone know the different types of adjustments that can be made to the beam pattern and where i have to adjust to on the headlamp? Thanks
    Ross
