Chris NottSky Insurance
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Alternative to adjustable rear tie bars???
    Instead of getting adjustable rear tie bars would these work on OEM tie bars? Seems a lot cheaper than Ł300. You can get the kit for about Ł100 and probably fit within an hour.
    Anyone interested?
    A lowered TT/R32 will have too much rear camber; left unchanged can lead to premature inner tire wear and reduced corner performance. The ECS TT/R32 Quattro camber kit can bring your TT/R32’s suspension geometry back into spec. Available in a 2 bushing kit for moderately lowered vehicles (less than 1 ˝”) or a 4 bushing kit for extra low vehicles.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,494
    I was going to get this kit myself, as I'm not too keen on the adjustable tie bars, they seem fragile to me, but asking for advice on here previously, this option offers limited adjustment, and is classed as a 'bodge' job over the tie bars.
    You've got to have a laugh! For Sale:LCR Brakes - ÂŁ400
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    yep, bodge job
    if your going to do it, do it properly!!
    KW adj tie bars for sale, pm me with an offer
    cheers
    ash
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    The Forge tie bars are TUV approved...so no bodge job, or fragile piece.
    They just work, and work well....and you can get to the adjustment easily.
    I would be very surprised if you'd even get enough adjustment on the bush type kit..and even more surprised if you'd ever get them adjusted again once they've been under the car for a while.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    mbs3's Avatar
    Nov 2007
    54
    Im going to chop and re-weld some standard bars to the right length. I was wondering if any one new when the bars are set ( for a - 25 mm set up) how much shorter they are? im guessing at taking 4 -5 mm out.
    Oh yeah before any one says, i am tight!
    And im a qualified engineer, so no it wont be a bodge!
    r32 bilstien shocks, H+R springs, custom code map........ and buel xb9 for proper petrol fun!
    s3ollie's Avatar
    Jan 2007
    749
    i say 4-5mm would be way to much as the bar is connected close to the center of the hub, by the time you get out to the outside of the wheel its going to have moved a major amount. you IMO would be better off making/copying an adjustable bar.
    8P S3
