Chris NottAH Fabrications
    p14va's Avatar
    Nov 2007
    44
    Wierd door locking issues.....
    Hi guys,
    Right after sorting out all the mechanical issues with the car time to move onto the electrics...
    I have to lock/unlock the car with the key no remote access (yet!)
    When I lock it from the drivers side all the locks are locked.
    But when I lock it from the passengers side or the boot, the drivers side doesn't lock.
    Also, when im inside the car and press the lock/unlock button by the drivers handle all lock/unlock except the drivers door??
    Finally, got a few fault codes on the vagcom saying alarm set off by drivers door and the bootlid.
    Im assuming its slightly connected and read a few thread of similar problems and the problem being a door contact switch?? yay or nay?
    also the bootlid one is supposed to be common??
    - Audi A3 1.6 -
    p14va's Avatar
    Nov 2007
    44
    ok its most probably the drivers door lock mechanism/switch
    does anybody have a picture of the boot lock mechanism or a diagram??
    - Audi A3 1.6 -
