danotto said:what are fmic like to fit how long does it take?
S4quatt said:Just out of curiosity, are there any FMIC's out there which keep the car looking standard?
Not too impressed with the pics i've seen where you can't get the front side grills back on etc.
Ess_Three said:Theres a FMIC behind this bumper:
A wee bit of trimming of the drivers side air guide to the standard IC (which I kept, since I was running an uprated SMIC in series) but all the grilles back on, no hacking of the bumper bar etc...
This was the FMIC:
I can't be done with all this flash-git silver FMIC and plished pipes...it has to be stealth, look standard, fit properly and most of all, work.
Star Performance did mine...although Forge built it to a Star design.
Anodised black, black powder coated pipes and Samco hoses.
You couldn't see it unless you looked for it...but it worked.
78 degrees inlet air temperature, after the std ICs, on the dyno at 1.7 bar of boost no: )...no more than 30 degrees with the FMIC fitted...and nearer 23 degrees with the FMIC and forge uprated SMIC.
They work, and work well...and best of all..you wouldn't know it/they were there.
Ess_Three said:Gains?
None. Nothing. Nowt. Sweet FA.
What you will get is the full potential for power that your re-map could produce, if it weren't getting heat soaked and reducing the timing to protect itself from the risk of melting things.
Basically, you'll get full potential power, all day, every day...and much less chance of heatsoak.
But, to get more power, you really need to have a bespoke re-map done to take acount of the cooler charge.
I think a FMIc will cost you about £500 ish...probably more if you change all the hoses to Silicone and all the clamps to Mikanor which will hold the pressure if you really start cranking the boost up.
I doubt I saw much change out of £1000 odd for both the FMIC and SMIC, hoses and clamps.
..for no real gains, except the ability to run higher boost, and start pushing things in relative safety.
It's still a worthwhile mod though...the S3 heatsoaks something silly...after 20 mins or so of fast driving - or less on the track - you can feel the power tailing off...with an FMIC you don't, so you keep the power you have, for much, much longer.
glen_jai said:Glen,
I couldn't find the forge uprated SMIC on their website? Where can I find it?
And also, how affective are they?
I am thinking of fitting only uprated smics as I don't like the idea of an fmic. It sits infront of the radiator. So even though the charge is cooled, I wouldn't have thought it'd be helping with the engine coolant temps.
Probably the reason why Audi decided to fit them as side mounts instead of a front mount, which would've been the more obvious choice (aka rs2).
Thoughts?
Cheers.
jojo said:I don't think they do them anymore, just give them a call or email, they are very helpful!
glen_jai said:Glen,
Thoughts?
Cheers.
Forge said:here to help
Forge said:we only ever did one set of twin side mounts , they were ok but didnt perform as well as the FMIC . so it made no sense to continue with them , we find the FMIC is good on chipped or big turbo upgrades.
The 007 P valve is similar in size to the oem bosch valve , the 006 is a larger bodied version , the function internally is the same , single piston single spring , both valves should fit under the engine cover with no issues.
As the valves a both designed as recirculation type valves one shouldnt really sound any louder than the other ...hope this helps
ChriS3 said:
