Badger5Monster Motorsport
Results 1 to 12 of 12
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Unhappy To replace gearbox or not to that is the question?
    car rattles from gearbox, but when i press the clutch pedal down it goes away. have had a couple of garages look at it without opening the box up as i'm short of the cash required to replace gearbox if it is that. anyway the VAG specialist thinks it's the gearbox and a gearbox specialist thinks it's the flywheel. now the question is has anyone on here had a similar problem if so what are the signs of either????
    thanks in advance....
    A3 TDI Sport 00
    A4 TDI Sport 04 Alacantra, Fishscale alu trim, GmbH bodykit, 6 speed box.
    May 2003
    Reading
    705
    Could it be clutch release bearing?
    Dec 2006
    N.Ireland
    369
    is it the release bearing rattling?
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    both the garages think it's not the release bearing..i thought it might be that...cheers
    A3 TDI Sport 00
    jeffers999's Avatar
    got boost
    May 2007
    pontypridd s/wales
    390
    Does sound like the flywheel to me mate ....
    1999 audi s3, silver recardo leather, lightly smoked windows,18" rs4 reps, full exhaust with de-cat, cold air induction, front mount intercooler, 13.850 1/4 mile @ 102 mph.A little vid on me running a 13.90
    http://s151.photobucket.com/albums/s...t=MOV00019.flv
    xbox gamer tag jeffers999
    PS IM AFTER A CENTER ARM REST ASAP......
    Car collection
    Audi s3
    Vitara fat boy jeep soft top
    saxo vtr , little track toy
    polo 1.4 beast
    spannah's Avatar
    Jul 2007
    N.London
    238
    I have the exact same noise, please update us on what the actual issue is
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Quote Originally Posted by spence_star
    i'm booked into the VAG specialist end of next week for a flywheel and clutch kit replacement...hopefully it wont be a gearbox issue. i will update you when i pickup the car.
    cheers
    A3 TDI Sport 00
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    spence_star
    do you feel a little vibration from the clutch pedal when you press it 2 or 3 mm down gently?
    A3 TDI Sport 00
    bouncer--daz's Avatar
    A dog is for life....not just for friday nights!
    Mar 2007
    Gloucestershire
    543
    I had a similar problem with mine which I noticed just after buying it. Again the noise went when i dropped the clutch. The whole gear box just went... luckily it was still in the 3month warranty with the garage, so I had a refurbed gearbox dropped in with a 12month warranty free of charge
    Daz - Audi A3 - 18" rs4 alloys - Weitec ultra gt 30mm kit - pipercross panel filter - tints all round - facelight rear lights - clear side repeaters - german style plates - flip out dvd touchscreen hu
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Well car is stripped at the garage, and has already had a new flywheel and clutch fitted...so they now think it's the gearbox...which was sent the gearbox specialist who says its fine but will change a few bearings inside. the only thing they said was that it has a solid flywheel ( i'm assuming this means a single rather than a dual mass flywheel) setup. the only thing i can think of is replace it with the dual mass flywheel kit from LUK that i supplied to them...
    your thoughts please......
    A3 TDI Sport 00
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    A lot of people fit the solid flywheel from a G60 golf/passat or 16v mk3 golf with a vr6 clutch kit. I have this set up, as do a few other on this forum.
    It's an improvement over the original clutch from a performance point of view, ie they are less likely to slip under full throttle.
    A characteristic of this setup is a slightly juddery clutch take up especially when reversing.
    Also you will often hear the rattling you describe from the layshaft bearing (I think) at idle. The rattle can be a little annoying, but its normal and nothing to worry about.
    I would stick with the solid flywheel, especially if you intend to remap the car.
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Quote Originally Posted by HTC
    well i picked the car today and they decided to replace the layshaft bearings and also removed the old (newish) flywheel kit and replaced it with the dual mass flywheel kit, it's the wifes car so i don't think she wants anymore power out it. the noise is no more!!!
    A3 TDI Sport 00
