AH FabricationsVolks Autos
Results 1 to 11 of 11
    Sep 2006
    Sunny Suffolk
    552
    Question DIY Front Pads & Disks Replacement - Tool Checklist
    Hi,
    I would like to replace my front pads and disks myself this weekend (weather permitting) and would just like to know if any S3 specific tools I may require.
    I have replaced pads and disks on my previous cars and used a G-Clamp to push the pistons in. Is this safe/correct with a 2001 S3?
    Would anyone happen to know off hand what size sockets/spanners I will require? Torque settings would also be grrrreat!
    Cheers,
    ICE
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    no special tools required for the fronts, when you push the piston back in release the bleed valve, then top up the lost fluid after, although I would recomend changing the brake fluid too. Rear brakes require a special tool, cost about 20 - 25 iirc from halfords or GSF
    rodenal's Avatar
    Oct 2006
    1,982
    You wont even really need to touch the piston on the fronts or do anything with the fluid. You should be able to just slip the new pads in and on to the disc
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    May 2003
    Reading
    705
    Haynes say:
    Guide pins 30NM / 22lbf
    Mounting bracket bolts 125 NM / 92lbf
    Sep 2006
    Sunny Suffolk
    552
    Thanks lads.
    I'm hoping to paint the calipers black while im at it.
    Cheers,
    ICE
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    what brakes and disks did you get mate
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    Sep 2006
    Sunny Suffolk
    552
    Ferodo DS Performance Pads (Not DS 2500's, but the replacement to the old DS 2000's I believe) - and Black Diamond Grooved Disks.
    Hope to change brake fluid when car is next in for a service.
    ICE
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    those are the discs im thinking of getting....
    could you post a pic once there on would love to see them on the car.
    Call of Duty Zombie Slasher.
    Oct 2006
    Morayshire
    17
    brake pads.
    Just finished replacing my Black Diamond Predator pads an hour ago, relatively straight forward, its a 7mm allen key for the guide pins, and you'll have to loosen the bleed nuts to push the cylinder back. the pads themselves are a straight forward fit however the wear indicator connector on the pads was a male, and so was the one on the car, so had to cut the female off the old pad and splice it onto the new one, no big problem though. Took about an hour all in all, once finished i topped the reservoir up to replace the lost fluid, and all seems fine now, going to take it into a specialist to get the brakes bled over the next few days just to make double sure.
    Cant help with the discs, sorry. Have fun
    Sep 2006
    Sunny Suffolk
    552
    Quote Originally Posted by cjhill
    I'll try and take some pics once they've bedded in.
    Quote Originally Posted by S3Matt1983
    Hmm, the guide pins you mention have thrown me a bit. As long as I have 7mm allen key, should it be obvious as to what I've got to do? :S
    Thanks for the info.
    ICE
    Oct 2006
    Morayshire
    17
    Should be obvious, once you get the wheel off and you start trying to get the callipers off the calliper carrier you'll notice that there are two rubber stoppers, one at each end of the calliper housing furthest away from you, pull the caps off and in there is a bolt with a 7mm hexy head on it, unscrew both of these and u can then slide the whole thing off the disc, probably leaving the outer pad resting on the disc, the rest is straight forward.
    Check this thread out should be all the info you need on here for both discs and pads.
    Disk and Pad fitting - how to?
