EM TuningBadger5
    Jul 2007
    85
    1.8T engine oils lines
    Hi,
    regarding the problem of white smoke on my car, is there
    another filter on the oil lines ? Something that can get blocked
    and cause some problems ?
    Thanks in advance
    Regards
    Jun 2006
    298
    Hi,
    water entering the exhaust or combustion chamber is the cause of white smoke. Oil will make blue smoke.
    What makes you think it's oil?
    Andy
    Jul 2007
    85
    I might be wrong, but the oil level was a kind of low.
    The coolant level on the other side was on the same level and I keep an eye on it frequently.
    When I saw the oil level and don't see coolant on the oil...
    If I have a coolant leak, where should I start looking at ?
    I've already made a compression test and haven't found anyhing strange on it
    so I doubt about the head gasket . . .
    Any ideas ?
