Hi guys,
I had a remap done last month and the car felt pretty good, however I did notice after a while that it seemed a bit sluggish in 4th when in higher rpm range 4-6k. I took the car in for a service at a local specialist and they hooked it up to th dyno, the figures seemed ok, 200bhp/225lb-ft, the graph print out was a bit shocking. The torque peaks at 2700rpm at 225 then drops too down 185 at 3000 which point it pretty much plateaus untill 4700rpm and then dives rapidly down to 115 at 6000rpm.
Also I had the car around 9 months before i had it remapped when I took it in it had no errors, today I was told i got the following fault: charge pressure control - negative deviation, which aparently means the ecu is looking for more boost than it is recieving? They said they couldnt tell of any immediate leaks but said it wasnt right.. any ideas on this? Bit depressing really
thanks,
Sat
thanks,
Sat
