Volks AutosMonster Motorsport
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By golf
Thread: Coilpacks on the way out?
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    When I start the car for the first time especially on a cold morning I have problems firing the car up. It starts on 3 cylinders and normally takes a couple of blasts of the accelerator.
    Well this morning it sounded like this for about 20 seconds. Kept sounding like it was starting on 3 then 4 then back to 3 and it was idling pretty rough to be honest.
    Would a fault have been logged? Does this sound like my coils are going to go soon?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    If it's misfiring on a cylinder a fault should have been logged on the ECU - do you have access to vag.com at all? - If so, you will get the standard engine misfire code (16684) and then another code to tell you which cylinder is playing up, it should be as follows:
    (16685 - Misfire cylinder 1)
    (16686 - Misfire cylinder 2)
    (16687 - Misfire cylinder 3)
    (16688 - Misfire cylinder 4)
    It's probably also worth checking that none of the coil packs have "popped up" as a loose coil pack won't make the spark plug connection properly, they should push into place on the BAM engine.
    Good luck
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Cheers Mike - don't think it has popped out as it's only first thing in the morning and possible when wet which would indicate a shortage of power.
    I think I need to buy a licensed copy of Vag-com.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    If the coilpack was faulty, then it would be shaking and running on 3 cylinders the whole time. If it's just for a few seconds during a cold start then it could be something else. Best to get it scanned.
    Nov 2007
    6
    not really true if its the same as coil packs on a peugeout,i had mine starting ruff in the cold mornings for ages and then kicking in!it died on me finialyl on the ay back from magny cour in france.!
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by cappsy
    In English now please.
    andywaddy likes this.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Thanks I presume the coil went rather the engine. In English would be good
    chesney's Avatar
    Oct 2007
    Aberdeen and Glasgow
    31
    On some peugeots if the coil pack is on the way out it the car can seem fine and have the odd missfire. Then all of a sudden it packs in.
    Well known fault in pugs.
    I understood him
