Craigybaby37_A3quattro
Since having my car mapped by jabba i keep reading other posts about there custom code mapping and everyone seems to be very happy with the results so am i the only person thats not 100% happy with there custom code mapping???
first problem is thr throttle has never felt the same since the map...ive spent £165 on a sprint booster with no luck and also re-alligned the throttle body with no luck either. As ive said before its a bit of a nightmare for pulling away and hill starts....sometimes it will be fine and others it revs the **** out of itself trying to pull out of junctions at 4000rpm with clutch spinning away which cant be good.
second problem is under normall acceleration u hear the turbo start to boost a little and you let off the throttle to change and sometimes it feels like it missfires and lumps as it comes off the power.
third problem is under hard acceleration in higher gears on motorways etc ill accererate in 5th from say 60mph upto about 80mph and once upto 80mph ill let off the throttle to hold the speed and the car will keep trying to put the power on and then let of causing the car to lurch back and forth and only when u completely let off the throttle and go back on will it stop.
and 4th problem is under hard acceleration in all gears the car boosts up nicely at 3000rmp and at 3500rpm u feel the power die down a little and there is no more boost and u can actually hear the turbo whistle away at 3000rpm and then dissapear completely at 3500rpm and not to be heard at all right upto 6000rpm
The car was mapped back in august and when it was done i had a new air maf fitted along with a new air filter (standard audi filter) and now i dont know what to do about it. do i call them up and explain everything and see what the offer me as the map must have some sort of warrenty right?? or do i take it elsewhere to somewhere called LPS in martlesham which is a lot closer to where i live and pay £80 an hour for mapping time and see what they come up with??
