Chris NottAH Fabrications
Results 1 to 7 of 7
    Feb 2004
    Middlesex
    79
    TaiPan CAI fitting
    Any body here got or fitted the QuickShift induction kit
    i'm just in the process of doing it now (11:45 am saturday)
    and i'm confused about where to route the cold air feed pipe.
    Does it go through the same hole as the original breather pipe or do i route oout under the engine bay some how?
    thanks in advance.
    Oct 2003
    Wilmslow Cheshire
    336
    Re: TaiPan CAI fitting
    Ir i remember right there is a hole in the front wing that can route down to the bottom of the bumper . You'll probably have to remove the battery to get a good fit. Ifyou look at the group buy thread for these im pretty sure some1 posted some pics of fitting. Hope this helps,Ta
    Jim
    Nov 2003
    Gloucester, England
    50
    I have just recieved mine and was wondering which way round the filter goes as I have not tried to fit it yet
    Feb 2004
    Middlesex
    79
    Theres a picture here that gives a general idea, it doesn't look like the cold air pipe is following the original hole in the pic.
    hope this helps you Dom
    http://www.audi-sport.net/attach/54954-filter.jpg
    Chris
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    That pic looks like Gambba's Quickshift. His is a Pre-facelift A3 (98 I THINK) so IIRC he fed the air feed down along beside the battery to the front lower grill. However, on the newer 8L A/S3's you can feed the pipe to the original hole in the wheel well, it only requires bending the feed a little to make it fit. This was done on JayBeeS3's Quickshift. I'm sure there are pics, so will look and post it if I find it. [img]/ubbthreads/images/graemlins/grin.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Nov 2003
    Gloucester, England
    50
    Cheers for the picture, thats not the way I thought it would go, judging by the inner I thought the end where you can see the filter and gauze pointing inwards would be the intake side not the MAF side, but heywhat do I know
    JayBeeS3's Avatar
    Jul 2003
    The Netherlands
    114
    piccie:
