Chris NottEM Tuning
Results 1 to 8 of 8
Thread: S3 Dash Lights
    Oct 2007
    S3 Dash Lights
    On my S3 the dash lights come on with the ignition however I find that as it gets dark outside I forget to switch the lights on. Is it possible to arrange for the dash lights to only come on when the lights are on
    Stuart
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Just keep your lights on at all times. We have about 6 hours of light anyway, so lights are required most of the time.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    You get used to it after a while. When I first got mine I kept thinking I had my lights on
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    As I'm sure you are aware, there is a headlight symbol that illuminates when the lights are on.
    Try to concentrate on that rather than the dash illumination perhaps.
    Sam-K's Avatar
    Has a throbbing red german.
    May 2007
    Near Aylesbury (home) Stafford (uni)
    473
    Umm. When it's dark.. can you not see where your going unless you have your lights on? surely thats enough reminder? lol.
    I like "Posh Fiats"
    Nov 2006
    Cambridge
    90
    Turn the brightness down, it helps both during the day, and at night.
    May 2003
    Reading
    705
    Not sure if the S3 instrument cluster has the same options as the TT one but you could try this if you have VAGCOM.
    http://www.wak-tt.com/vagcom/vagcomdashillum.htm
    I was sure I had found this before it has just taken me a while to find it again.
    I will try it on mine sometime when I get the chance but I'm moving house tomorrow so have slightly more pressing things to do.
    Oct 2007
    Brilliant this works with the S3, I have set it to pointers only and will see how it goes
    Stuart
