Results 1 to 12 of 12
    Oct 2007
    Stockton On Tees
    29
    S3 not sitting level.
    My car is sitting lower on one side than another! It seem that the drivers rear wheel is sat further in the arch than the pass side so it looks a bit wonky from the back . My car has been stood for a while unused but it has been in use for couple of weeks now and still hasnt sorted itself out.
    Any ideas? Cheers
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    Snapped springs, knackered shock?
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    flat tyre?
    Oct 2007
    Stockton On Tees
    29
    Its just gone through a MOT with flying colours so i am assuming shocks and springs are ok. might be worth checking myself tho. Tyre pressures are all ok. Thanks for you replys.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    the spring can be hard to see, depends on how good a job the mot station did. Its the end of the spring that snaps.
    red to red black to black blue to bits
    Jan 2005
    Irvine, California
    57
    Just out of curiosity - will there be any obvious sounds/signs if your spring has snapped? (silly question maybe!!)
    My car was creaking quite a bit recently, which I put down to ARB's after some reasearch from this site.
    Now the creaking has gone away, and it sounds like a rattle coming from the passenger rear.....obviously something isn't right and I am going to get it checked out, but I don't want to spend money on parts I don't need straight away if the problem is being caused by somethng else?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I take it the car is all straight with regards to any accident damage?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    I reckon it's a snapped spring myself, or seized arb bushes, MOT testers will generally look at your suspension with the car suspended in the air, so they probably wont spot the height difference.
    You've got to have a laugh!
    Nov 2006
    Aberdeenshire
    111
    If the spring has snapped at the very bottom coil (which mine had both sides) they may not have noticed at MOT. When they had the car jacked up the spring could have moved slightly, when all the weight went back onto it. I never really noticed mine until I did the rear discs and pads. When it went back on the ground it was sitting down at one side.
    Think its quite common for them to break springs?
    2007 Ibis white S3.
    Oct 2007
    Stockton On Tees
    29
    Will check the springs today and let you know. Cheers
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    is it on level ground?
    Oct 2007
    Stockton On Tees
    29
    UPDATE!!!
    Spring has snapped!! The botttom coil has broke off. Anyone know where the best place to get 2 new ones is? Thanks for pointing me in the right direction people. Cant believe it only past a test 3 days ago!
