Results 1 to 8 of 8
    Oct 2007
    27
    Best place to buy service items?
    Hey all, my 2001 s3 has jus clocked over 100k and is also telling me its time for a service, i really cant afford to take it anywhere and want to do it myself as im not too bad with a spanner (fitted an audi 16v engine to my 1.6 golf driver ) can anyone suggest wheres best to go for the parts needed like oils etc from the following items from the service FAQ on here, and how much roughly each item may be? If theres enough input on prices etc maybe this can even be a FAQ. many thanks for any help, James
    Normal service
    Engine oil dropped and replaced
    Engine looked at for leaks and damage
    Battery level checked
    Antifreeze checked
    Dust and pollen filter replaced
    DTC's checked and cleared
    Exhaust checked for leaks
    Brake pads checked
    Brake system checked for leaks and damage
    Brake fluid checked
    Engine, gearbox and CV boots checked
    Oil level in gearbox checked
    Swivel joint boots checked
    Under body sealant checked
    Tyre tread, wear pattern, and pressures checked
    Track rod ends checked for play, and boots checked
    Door check straps and lock cylinders lubricated
    Sunroof guide rails cleaned and lubricated
    Lights, indicators, hazards, dash lights and horn checked
    Headlamp washers and settings checked
    Headlight alignment checked
    Service indicator reset
    Additional service work every 20k miles
    Haldex Oil changed
    Additional service work every 40k miles
    Air filter replaced and airbox cleaned
    Hydraulic fluid checked
    Spark plugs replaced
    Haldex Oil filter changed
    Additional service work every 24 months
    Brake fluid changed
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    any Audi Parts department, GSF Or Eurparts for filters and plugs for service parts
    Halfords for oil if its on special or i use www.Opieoils.co.uk who will supply you with engine oil, gear oil, brake fluid, coolant all for very competitive if not the cheapest prices.
    Oct 2007
    27
    Im NEVER gunna use euro car parts again, was disgusted with the service and their inablility to send the correct parts..... when u think u are saving money with the prices they offer and then end up payin so much more in phone bills and returned items which are still replaced with wrong ones after explaining exactly what i need to the useless fool on the phone who thinks he knows everything about every car and is a top mechanic because he works behind the counter of a parts dept grrrr, sorry rant over, i dont like ECP!
    Are gsf items suitable and quality enough to use on a car i just spent nearly a years wages on?? VAG dealer parts are so expensive!
    I have heard good things about opie will visit my local shop
    Bit of a poll, main dealer service items against the cheaper alternative (gsf etc) thanks
    Feb 2004
    2,036
    GSF service parts shouold be original equip items, Mann filters they sell are bteer than Audi ones IMO! They stopped doing quantam oil which was a steal compared to dealers, but they now do Total stuff that is equivalent.
    Still have VAG coolant though.
    Have you had a cambelt service on your car yet? If not, this would be a wise thing to do ASAP.
    Jun 2003
    World of my own
    9,813
    Quote Originally Posted by Fat Tony
    Audi don't make any of these parts, they are just rebadged with the 4 rings and the price doubled for the privilege.
    GSF supply the original manufacturers parts - Mann filters, Jurid pads, Brembo discs etc. Very good in my opinion & very knowledgeable. Web site is shyte though.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    agree that gsf web site is v v poor. Just opened a store in huddersfield so that should save me a few miles to get bits.
    red to red black to black blue to bits
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I don't think Audi actually charge that much for the general service bits. however if you want to save a bit get them from vagparts, I did last time I changed all the filters / dv etc.
    Jun 2003
    World of my own
    9,813
    Audi only charge about 40% over the real price so well worth it for peace of mind that you're being totally ripped off.
    Case in point:
    Rear Discs & pads for my TDi:
    Audi price £102.23 incl VAT
    GSF price £60.55 incl VAT
    These are the same parts, just not in an Audi box.
