Hey all, my 2001 s3 has jus clocked over 100k and is also telling me its time for a service, i really cant afford to take it anywhere and want to do it myself as im not too bad with a spanner (fitted an audi 16v engine to my 1.6 golf driver ) can anyone suggest wheres best to go for the parts needed like oils etc from the following items from the service FAQ on here, and how much roughly each item may be? If theres enough input on prices etc maybe this can even be a FAQ. many thanks for any help, James
Normal service
Engine oil dropped and replaced
Engine looked at for leaks and damage
Battery level checked
Antifreeze checked
Dust and pollen filter replaced
DTC's checked and cleared
Exhaust checked for leaks
Brake pads checked
Brake system checked for leaks and damage
Brake fluid checked
Engine, gearbox and CV boots checked
Oil level in gearbox checked
Swivel joint boots checked
Under body sealant checked
Tyre tread, wear pattern, and pressures checked
Track rod ends checked for play, and boots checked
Door check straps and lock cylinders lubricated
Sunroof guide rails cleaned and lubricated
Lights, indicators, hazards, dash lights and horn checked
Headlamp washers and settings checked
Headlight alignment checked
Service indicator reset
Additional service work every 20k miles
Haldex Oil changed
Additional service work every 40k miles
Air filter replaced and airbox cleaned
Hydraulic fluid checked
Spark plugs replaced
Haldex Oil filter changed
Additional service work every 24 months
Brake fluid changed
