You have to use the G12 they recommend as the seals in the system are design to work with the G12. If you use the older blue stuff you can degrade the seals and get a whole heap of problems
disconnect the bottom hose from the rad and let it **** out. i didnt bother with mine i just topped up with normal anti freeze and its been fine. All these main dealers just tell you to buy their own special stuff so that you buy it from them!
Ive read so many horror stories about not mixing diferent coolants together and I havent a clue as to what coolant is in the the car so I wanted to drain the system completely.
Also whats the best way to mix the water and coolant when adding fresh (water in first then coolant or mix then add?)
