EM TuningAH Fabrications
    davidelson
    Nov 2007
    monmouth
    Angry A3 tdi 1st / 2nd gear selection problem
    i have a problem engaging 1st and 2nd gears - the clutch when released stalls the engine
    the engine will engage reverse and 3rd upwards and will drive
    any thoughts
    someone has said there may be a cable adjustment or breakage to the lower ratio selector???
    thanks
    david
    Feb 2004
    2,036
    A bit more info fella, that makes not much sense! !
    What happened to cause this? Did it just start doing it, make a bang, do it while driving?
    You say it stalls when the clutch is released? Is this because the gearbox is locked up solid in these gears, (ie gbox failure) or because its not actually in 1st / 2nd, rather in 3rd or 4th, meaning it stalls as you aint giving it enought revs?
    Have you tried engaging "1st or 2nd" and rocking the car forward form outside, engine off, to see if it all turns over?
    bit more info would help us.
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    it's a common fault on 6 speed box in cold weather. Synchromesh is not good
    on early 6 speeders
    does it get better or always bad?
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
