Chris NottAH Fabrications
Results 1 to 9 of 9
    RAPS3's Avatar
    Moo Moo Land
    1,067
    Uprated Clutch & Flywheel ?
    The clutch / flyhweel on my S3 has been a bit suspect for a while know. No slippage just an annoying vibration feel through the pedal when taking up bite and a very short travel, with a snappy feel to it.
    I've done the dealer thing and they say theres nothing wrong. But I've drove 2 other S3's now and somethings definately not right. The clutch felt smooth with no snappiness.
    Anyway I'm going to change it in a few weeks and this is where the question arises.
    Do I go for option 1 which is to replace the clutch and dual mass flywheel with geniune Audi parts. I can get these for around 587 (trade)
    Or Option 2 which is to fit a lightened flywheel and uprated clutch. Ive seen this
    ECS Tuning
    with which the current exchange rate comes in at 733.
    The car is chipped by MTM so there is the issue of a standard clutch going again in the future. But I dont want a sharp visceous clutch with the amount of town driving I do.
    Also surely Audi made the flywheel a dual mass one for a reason, can anyone forsee engine problems by removing this for a solid Aluminium one?
    What do you guys think becasue as you can tell I havnt a clue which way to go.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Uprated Clutch & Flywheel ?
    Paul,
    I'd be tempted to go with an uprated set up. Plus, you can test it on by behalf, and if you like it, I'll maybe invest!! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    I'm sure the ECS product is very good...
    But, at this year's Autosport show I was speaking to Dick Richards from Mardigras Motorsport at Silverstone...he was telling me all about the Helix stuff..
    I was specifically quizzing him on uprated 1.8T stuff with high clamping forces.
    Apparently Mardigras Motorsport are one of the UK distributor of Helix stuff:
    ..ands Helix do an uprated and lightweight flywheel that allows the use of a larger clutch.
    Perhaps there are more details on Helix's site:
    Helix Clutches
    The cost was somewhere around the 600-700 mark for the flywheel, clutch cover, clutch plate and the release bearing. I thought this was pretty good.
    Helix do both a cerametalic and an organic plate...the organic I was told would clamp over 330lb-ft...which should do you or I nicely.
    Dich reckoned that the organic would be ideal for fast road use...
    You could do worse than give Mardigras a call...they are unfeasibly helpful (I used them all the time I had my Integra Type-R as they race them!)...I'm sure that Dick could offer advice / assistance.
    When my standard item finally lets go, that's where I'll be heading.
    RAPS3's Avatar
    Moo Moo Land
    1,067
    Glen - cheers I'll give them a call I think. I'm going to keep on looking into this until I'm certain, as I dont want to have to pull it all apart again.
    These are the details of the ECS kit -
    [ QUOTE ]
    ECS Tuning Stage III Clutch Kit with Lightweight Aluminum Flywheel (9lbs)
    Complete kit including ECS lightweight aluminum flywheel & hardware
    approx 30% more clamping force than stock clutch!
    Faster revs due to lightweight flywheel
    Free up lost horsepower with almost a 15lbs difference in clutch set-ups
    Kit uses Special heat treated clutch pressure plated & Kevlar lined clutch disc
    Kit is good to 275-325 wheel horspower & approx 325lbs of wheel torque
    Excellent pedal feel, retains OEM type pedal feel
    Kit includes the following parts:
    ECS lightweight 9lbs aluminum flwheel
    OEM flywheel bolts
    ECS Stage 3 Clutch Pressure plate & disc
    OEM Pressure plate bolts
    Installation:
    Torque Flywheel to crank 60Nm.(44ft.lbs.) + 1/4" turn (90deg)
    Torque Pressure Plate to Flywheel 20Nm.
    IMPORTANT
    Kevlar Break in period of 450-500 miles of normal stop and go driving before the intended use of the clutch can be initiated. NO full throttle shifting or compression braking should be performed prior to completing the brake in period. Breaking in period allows the friction material to properly seat against the flywheel and pressure plate.
    $1349.95
    [/ QUOTE ]
    Do you have any thoughts on the removal of the dual mass flyhweel for a one piece ali one?
    The dual mass version takes up some of the initial loadings on the drivetrain doesnt it? So surely if I remove it the forces need to go somewhere.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Understandable...
    The only thing going for a UK based kit over a US based kit is the access to the manufacturer...I'd feel more happy being able to walk up to their door and create a scene...rather than dealing with someone over a long distance phone call...or trying to get them to return an e-mail! (not as easy as you might think!)
    [ QUOTE ]
    [/ QUOTE ]
    Yes, the initial shock is reduced...but the main advantage is less noise and vibration.
    Sure if you drop the clutch and unleash over 300 lb-ft, there's going to be stresses...but the dual mass thing will soon have wound it's self up tight so after that point there's no difference.
    Everything will take more of a bashing for sure..but just how much is up to the driver.
    At the end of the day...here's an example...
    Porsche GT3 - comes with dual mass flywheel.
    GT3 Club Sport does not...it has the single piece lightened part...no there differences except a bit more noise and a bit more vibration / harshness letting the clutch out.
    So, it can't be too bad for the car, can it?
    Sure...it's going to be less civil in traffic...fractionally so.
    Sure, a really light flywheel CAN make it easy to stall at junctions - if you don't give it enough revs! (I have one in my GTI...I know all about it)
    A single mass may be a bit more noisy, and vibrate a bit more than a dual mass...
    I don't drive mine to work in traffic...so it wouldn't bother me!
    I'd (and will when the time comes) fit a light flywheel and uprated clutch...but I wouldn't fit a paddle clutch for the road...they are just silly!
    You should be OK with a light flywheel and a full face uprated clutch though...
    Jun 2003
    Bromley
    305
    [ QUOTE ]
    Ess_Three said:
    The only thing going for a UK based kit over a US based kit is the access to the manufacturer...I'd feel more happy being able to **** up to their door and create a scene...rather than dealing with someone over a long distance phone call...or trying to get them to return an e-mail! (not as easy as you might think!)
    thats an interesting habit [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    sorry, had to point it out.
    s8n
    s8n's Avatar
    Feb 2003
    Sydney, Australia
    207
    A friend of mine recently enquired about a uprated clutch/flywheel and he said there were stalling issues??
    My clutch feel suxs and i definately want something that can handle 350hp for APR's upcoming Stage III, know of any around that are well priced?? Stock feel would be nice too [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Its a every day car.. ECS looks good but doesnt hold the power I want to acheieve
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    Heh-heh...
    That's me forgetting to let go of my sad nightshift fantasies and step back into reality!!
    Anyway...I think I got away with it! [img]/ubbthreads/images/graemlins/angel.gif[/img]
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    To be honest, I very much doubt the ECS clutch will prove to be a problem with 350BHP.
    It's not power that wrecks clutches...it's torque.
    The power is made too far up the rev range to cause a clutch real grief...normally, once the clutch is engaged and the engines past peak torque, it'll hold plenty more than the manufacturer states.
    It's peak torque you have to worry about.
    If I drop the clutch at 3500RPM, my clutch and drivetrain have well over 300lb-ft to sort out...if the clutch holds, the rest take the strain...usually resulting in all 4 tyres spinning up....
    If you have crap tyres...they spin.
    If you have sticky rubber...you are unleashing a whole lot of force!
    Regardless, you'll be lucky to gry away with that more than a handful of times on a standard clutch...that's why mine won't be seeing another 1/4 mile strip for a while...
    As long as I don't do standing starts mine doesn't complain...despite putting osmetimes upwards of 330 lb-ft through it.
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    Rich you must get one hell of a backhander from your sales teqniches you use. [img]/ubbthreads/images/graemlins/grin.gif[/img]
