EM TuningBadger5
Results 1 to 11 of 11
Thread: HID Kits
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    HID Kits
    Im just about to order a set but there's thousands to choose from!
    Going either 6000k or 8000k
    Mate of mine got a set from HK on ebay had them in his astra coupe for over a year now and they're still going strong?
    Just wondered if they're was a recommended kit a few of you have used?
    The uk based kits seem to go for around 100-200 GBP. When there's no difference to the HK 50GBP kits.
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I think you'd be a fool to get a 8000K kit. Do you actually want to see anything?
    Then you'll need from 4300K to 6000K max.
    I have a JBS supplied 6000K kit and its perfect.
    Co-incidentally, HID bulbs are meant to last the lifetime of the car.
    <Insert meaningless geeky specs here>
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Oh ok then just a mate of mine had 8000k in a GT TDI and they looked pretty good. I do have projector lights so they might come out bluer in mine?
    How much are JBS charging? Just when you see the difference in HK to UK Prices its quite a bit different.
    J
    A3 1.8TS
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    8000K are very blue.
    The higher you go up, the less visible light it produces.
    rodenal's Avatar
    Oct 2006
    1,982
    Yeah 8000k is very blue/purple
    The kits are all pretty much the exact same, i'd get a HK one.
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jaywoo_A3's Avatar
    Audi dead, 2.0T all the way!
    May 2006
    Derbyshire
    509
    I got a 6000K kit second hand off one of the members on here for &#163;50 its perfect,
    RichA3turbo @ JBR does a very good kit for about &#163;150 i think. thats what he has fitted to his A3.
    BLACK AUDI A4 B7 2.0TDI 140BHP S-LINE AVANT
    RED GOLF MK5 2.0TFSI 253BHP GTI
    BLUE GOLF MK3.5 2.0 110BHP COLOUR CONCEPT CABRIOLET
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Ok 6000k it is then after seeing how blue the 8000k comes out!
    I'll order a set from HK me thinks! Not being horrible but for 150 you could get 3 kits for that sort of price!
    A3 1.8TS
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The ballasts regularly fail on the Hong Kong Phooey kits. Also try and find a 5000k kit if you can, the best colour temp IMO. 6000k is pleasant enough but still has a hint of blue, and 8000k is for the Jap Crew as far as I'm concerned.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,370
    are these kits plug and play? or is there some fiddly wiring to be done?
    Do people still have the issue with the DIS showing a blown bulb because they draw so much less power?
    I would be very tempted to get a set if they are any good!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Almost complete plug and play. You do need to make a hole in your rear headlight covers for the HID wiring to go through but they provide a rubber bung.
    No issues with DIS or anything else.
    If the HK kits really are only 50GBP then it'd be OK to just buy a new one if the ballast failed.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The kits are plug and play, but like Dave mentioned you will have to drill a hole through the back of the dust cover. The sellers usually have a year warranty on the ballasts and bulbs though so after a bit of hassling them they usually send you a new ballast or bulb.
