Results 1 to 10 of 10
    jesters3's Avatar
    The Shire's
    1,516
    Fuel pressure - S3
    Arvo, a couple of times when I have gone to fill up, there seems to be a lot of pressure coming out of the fuel tank. As a result I have to keep the cap on and unscrew it slowly to let the air out; if I take it off straight away petrol spews out. This lasts for a good 30 seconds.
    I smell petrol every now and again from the front. I'm thinking I may have to get the fuel filter changed as the build up may be from here.
    Any ideas?
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    change the fuel filter and see if its any better, simple job if up on ramps
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Mine makes a little chirp which lasts under a second, and no fuel spirts out, get it checked mate.
    You've got to have a laugh!
    jesters3's Avatar
    The Shire's
    1,516
    Yeah not brilliant, going to get the filter replaced as it has done 149k worth of fuel! Hopefully that should fix it.
    Jester
    Sep 2007
    81
    Quote Originally Posted by jesters3
    do it yourself, it takes like 5 minutes?
    jesters3's Avatar
    The Shire's
    1,516
    Will do, Getting the filter tomorrow from VAGPARTS and doing it at the weekend, seems straightforward enough, just have to remember to depressurize the system before I crack on!
    Jester
    mazzy's Avatar
    Jan 2004
    West Midlands, UK
    299
    So does changing the fuel filter resolve this issue??
    Jun 2006
    712
    even if it doesn't it's worth changing anyway for the sake of a few £ and the fact that about a million litres of fuel have passed through it.........
    Aug 2009
    judging from there being no more posts i take it replacing the fuel filter solved the problem? I know it was about 2 years ago but im just asking because i have the same problem!
    jesters3's Avatar
    The Shire's
    1,516
    No i'm afraid not.
    The issue came down to a fubar gravity valve (part 14)
    This meant dropping the fuel tank to get to the part and then to replace. The part is about 5 but takes 3-4 hours to sort out.
    I had to get it done at a Stealers and it cost me 500ish all in. If you get this done at an indie it should be half the price.
    Jester
