Sky InsuranceEM Tuning
    Jan 2007
    58
    lumpy idle..no fault codes....what things can i check?
    cars has had lumpy idle for some time now.its starting to get a little bit worse now.i was guna try cleaning the maf sensor and also maybey change the temperature coolant sensor as this aperantly doesnt always show fault code. any other ideas people?iv had the throttle cleaned and reset aswell.didnt help.
    Jul 2005
    2,488
    just check the other usual stuff really, maf and lambdas.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Have you checked for air leaks?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I concur, vacuum leaks are always a good source of lump idles.
